As the weather is too unpredictable for a proper test, I now did a highly unscientific 10 minute test.
Shower + cover = ~tropical rain
I sealed the coat as best I could, and left it in the shower for 10 minutes.
TinyPic - Share The Experience!™
From what I could find the nylon does repel most of the water.
There is a slight condensation build up inside, but I would guess this is typical for any air tight fabric, nothing serious. The coat was mostly dry inside. I could find drops close to the openings, but the part where the camera body usually sits was dry.
It should in other words survive at least 10 minutes of tropical weather
I will try leaving it in the shower for an hour or two, and see if that changes things.
