07-30-2009, 02:46 PM   #1
Pentax K100D Powers down immediately
I have a Pentax K100D that I have been shooting with for years. Last night, I put new batteries into, powered it up. The battery full symbol goes on along with the '----" and them immediately shuts down. I tried several different sets of batteries.
Any clue as to what might be going on?
Thanks in advance
Paul
07-30-2009, 07:59 PM   #2
Are you talking about rechargable batteries? If so I had the same thing happen with my K100..it is a common problem...something to do with voltage (all beyond me) but what happens is the camera refuses to reconize that the batteries are charged. It happebed to mine after a year or more of use. Solution? I switched to lithium and one set lasted for 12 months.
07-30-2009, 08:04 PM   #3
code4code5's Avatar
QuoteOriginally posted by ozlizard Quote
I can second a recommendation for Energizer E2 lithium batteries. They seem to last forever in a K100d body and are more versitile for use in extreme cold. (Although, not much of an issue in July.)
07-30-2009, 10:38 PM   #4
Ash
Community Manager
Ash's Avatar
By 'new' batteries, what type do you mean?
If rechargeables, I wouldn't go for cheap brands as they run out of juics-carrying ability real quick - and the K100D is *really* power-hungry.
If you use once-only batteries, I second the high-powered lithium batteries suggestion like the E2s.
07-31-2009, 01:34 PM   #5
I am using E2 batteries
I am using the Energizer E2 lithium batteries.
I have purchased 2 different sets at different stores, same thing happens
Any other ideas?
07-31-2009, 05:22 PM   #6
Try different SD card? Make sure the SD card slot door is closed?
I had a similiar problem when I was playing around with the SD card door open...maybe this relates to your problem?
batteries, camera, dslr, k100d, pentax, photography
How to stop Dust alert. Please help immediately. sashe3320 Pentax DSLR Discussion 4 10-29-2010 10:46 PM
K-7 starts then immediately turns off wjax Pentax DSLR Discussion 9 09-19-2010 03:47 PM
Flash firing immediately on "2s delay" drive mode oguzgel Pentax DSLR Discussion 5 03-30-2008 01:20 PM
All times are GMT -7. The time now is 01:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
