Originally posted by lythari I noticed that the lock is on the grip side. I've tried applying pressure directly on top of it but that still doesn't work
Do you hear a click when push the flash back? If so but the flash doesn't lock, then quite possible the electronic release hook was defective and you might need to replace it (the whole top has to come off). If you don't hear the click, then you can loose the hex screw on the pop-up flash a little till the flash lock easy enough w/o feeling loose. That screw is threadlock btw.
