08-03-2009, 03:00 AM   #1
K20D metering query
Hi
Is it possible to use matrix metering when using a M type lens, obviously having set the A ring for permission, the manual is not clear on this point.
I normally use Spot but wondered if it is possible to use matrix?
regards
08-03-2009, 03:09 AM   #2
No, it is not possible.
As I understand is you set matrix on dial, it'll use center weighted.
08-03-2009, 04:47 AM   #3
Actually, it's possible, with a little trick : you have to short all the mount's contacts (including the recessed "A" contact!). this way, the camera will think it has an "A" lens mounted, and enable Matrix and PTTL features.
But doing this will not give the body two important information : focus distance & real aperture.
These inormation are used in the Matrix metering, but to what extent, I don't know...
Anyway, all I know is that my tests using M lenses, Matrix metering and P-TTL flash all worked and produced satisfying pictures.
Maybe the results would have been different with a real A lens, but I still have to do the test...
camera, dslr, matrix, photography
Light Metering Mode K20D mattmiles Troubleshooting and Beginner Help 3 12-02-2009 07:55 PM
k20d metering with M lens wasim_altaf Pentax DSLR Discussion 5 10-06-2009 10:15 AM
Metering Modes (on K20D) Mann Pentax DSLR Discussion 17 06-04-2009 07:46 PM
query for printers: K20D microbanding? janosh Digital Processing, Software, and Printing 0 03-23-2009 07:52 AM
K20D P mode query Arpe Pentax DSLR Discussion 10 04-20-2008 06:42 PM
All times are GMT -7. The time now is 07:34 AM. | See also: NikonForums.com, part of our network of photo forums!
