08-08-2009, 03:10 PM   #1
K20D problems
I have never head of this problem but when I have the K20D hooked up to the 50-135(brand new) it will not work what so ever. It will not autofocus at all. When hooked up to some NON SDM lenses it will work, but seems to hunt quite a bit. Also when it finally wants to trigger it takes 3 pictures in a row. We have reset the camera settings and also disabled auto bracketing. Any ideas? Thanks so much.
Barry
08-08-2009, 04:33 PM   #2
Blue's Avatar
It could be a lens issue. Did you get it via mail or local shop? Perhaps you need to try another lens that has sdm to verify whether or not its the body if you got it at a shop.
Edit: Or are you the rental shop?
08-10-2009, 10:20 PM   #3
Take a small piece of mylar or duct tape and cover the spot where shaft extends out of the camera for non sdm motors.Attach the lens and see if it works.If it works its a communication between lens and camera.Generally the lens is the culprit.Before you try this check the 2 contact points on the camera and lens to make sure the contacts are clean.Good luck.
08-10-2009, 11:51 PM   #4
Ash
Community Manager
Ash's Avatar
The 3 actuations in a row without bracketing is a little weird.
You may need to have both checked out - carry out the above suggestions and let us know how you go.
08-13-2009, 07:49 AM   #5
GLXLR's Avatar
QuoteOriginally posted by pentaxdude Quote
The shaft?
08-13-2009, 02:02 PM   #6
Mallee Boy's Avatar
Hi Barry,
I imagine you have done this....but:
thoroughly clean the contacts on the lens & camera, if that doesnt work I would be sending it back pronto.
Cheers
Grant (one & the same that is making a rental enquiry )
camera, dslr, k20d, photography
Some problems with my new Pentax K20D Saul Pentax DSLR Discussion 18 02-10-2009 06:51 AM
problems about K20d gemini Pentax DSLR Discussion 15 01-26-2009 03:51 PM
New K20D - Focus problems jasonfen Pentax DSLR Discussion 2 11-24-2008 10:40 AM
2 NEW PROBLEMS! k20d Isaac314 Pentax DSLR Discussion 19 10-04-2008 05:22 AM
Help K20D Problems sagaboy Pentax DSLR Discussion 14 09-11-2008 06:47 PM
All times are GMT -7. The time now is 05:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
