OK 4 ish years later and I'm back at it again.
I hadn't done much with my K200D for some time as i found it had a few stuck pixels that the cameras firmware just will not map out.
Going back through all my photo's I find it was a fault from new (day one).
You can imagine my disappointment, after all we buy these camera's for their high quality images.
This and the battery issues prompted me to just pack it away and give up on Pentax for some time.
Well I've started to get a bit of interest again in DSLR since seeing two new items released.
The
hd-pentax-da-55-300mm-f4-5.8-ed-wr lens HD Pentax-DA 55-300mm F4-5.8 ED WR Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
And the
pentax-af-540fgz-ii flash PENTAX AF 540FGZ II reviews - Pentax Camera Accessory Review Database
(Both weather sealed).
Since buying the K200D in all this time I still have not seen a replacement body I like. (AA battery support [in main body], Weather sealed body, penta prism (not mirror), Battery Grip option, live view, & lastly HD video support.
So I'm tossing up buying some new accessories like this lens and flash to use on my K200D once again until a newer model finally comes out that I like.
This is also assuming that the dreaded stuck pixels don't annoy the hell out of me again. And that I can get around the AA battery issue.
Anyhow this brings me back to the original subject.
(Battery issues).
Now I have noticed some interesting things since playing with the camera again.
I am currently testing with the following batteries. (Both new & used).
- Sanyo Eneloop [1900mAh]
- Varta ready2use [2100mAh]
- Aldi Active Energy [2300mAh]
- Aldi Ultracell [2000mAh]
I have noticed something interesting.
Regardless of the brand of battery the camera still plays up the same.
I also cleaned the battery terminals of the camera and batteries with alcohol just to be sure and did get some improvement after this.
But the big thing is for the camera not to play up the batteries need to be freshly charged.
let them sit for a few days and bang, same problem.
The camera just does not tolerate the lower resting voltage of the batteries. However cycling the same rejected batteries in the c9000 charger @500mA discharge shows perfect "as new" capacity. (Nothing wrong with the batteries).
I really think what's needed is a firmware update for the K200D that recognises that the lower voltage is acceptable.
Now back on to chargers.
I have noticed that there is now a new charger that to me looks to be based on the Maha c9000 design but with some new very nice features.
It's the
SkyRC NC2500 Charger.
NC2500 Charger
This charger has the interesting ability to link to an Android device and display real time statistics on the battery as it's charged and discharged.
You can actually see the voltage curve of the battery as it's discharged over time.
This would be very handy for knowing exactly how the different branded batteries react.
This charger is now also on my shopping list. They run out at about US$99 + postage.
I'll post more info in future as I'm sure this is going to be an ongoing issue for many K200D owners.
