05-13-2007, 03:42 AM   #1
Community Manager
Ash's Avatar
Non-TTL flash use with K100D
Settling for a simple auto twin-flash fow now I'd like to know from you experts how best to use such a flash gun with my K100D (trigger voltage tested OK). It's a Woctron 2820 twin (GN28) with bounce and swivel. Can I only use M mode on the camera?
05-13-2007, 07:39 AM   #2
Match the ISO and the f-number for different auto settings (for the camera and the flash). Check for the exposure, if it is too bright, close down the f-number a bit (against what is indicated for the flash's that auto setting position) and open up if the pics appear dark. Do check and calibrate for both direct and rebounced flash, which the exposure results maybe somehow different. Once calibrated, it should work fine.
To control the exposure of ambient light, i.e, usually the background, set the Tv in M mode (longer Tv to get more light and higher Tv to cut ambient light).
05-13-2007, 10:06 PM   #3
Ash
Community Manager
Ash's Avatar
Thanks RiceHigh. Much appreciated. Takes a little getting used to...
camera, dslr, flash, k100d, non-ttl flash, photography
I need to find an inexpensive P-TTL flash for my K100d Grimlock Flashes, Lighting, and Studio 16 12-16-2008 08:36 PM
Flash recommendation for K100D - P-TTL or Auto? geofferiah Flashes, Lighting, and Studio 3 05-23-2008 05:56 AM
k100d w/ non Pentax flash: no ttl? Rafael Pentax DSLR Discussion 3 12-30-2007 08:37 PM
Pentax K100D + Sunpak MZ-440AF TTL Shoe Mount Flash? Deni Flashes, Lighting, and Studio 2 07-06-2007 07:11 AM
K100D and TTL Flash, is possible? Aneopa Flashes, Lighting, and Studio 15 02-15-2007 08:42 AM
All times are GMT -7. The time now is 05:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
