08-11-2009, 06:19 AM   #1
seliscan's Avatar
Need help in a problem betwen a Samsung GX-20 and a Sigma 17-70
Hy,
I have the next problem and I'm searching for help from persons who know the problem or have experience it themselves...
I bought 2 months ago a Samsung GX-20 with a kit lens and few days ago I managed to spare fond for a Sigma 17-70 f/2,8-4,5
(witch is a superb less for Pentax users).
The problem is that the Sigma has a huge front focus on my Camera, and it could not be resolved even with a -10
calibration from the menu.
I reported this problem to the Sigma-Pentax representation in Bucharest (county Romania) and they asked to send them the
camera + objective to see if it can be resolved. After a day, they called me and sad that the lens is perfectly fine and
worked perfectly on two other Pentax cameras and asked my if I had the same problem with my kit lens, and I said no. The
answer was that must be an incompatibility form my Samsung Camera and Sigma lens and I must ask for advice to Samsung.ro
. I did that but the guy there was overwhelmed by the problem and sad that he can not help me - how ironical...
So what is there to be done is this situation, the guys from Pentax-Sigma Bucharest have a program for Penatx camera
calibration in conjunction with Sigma Lenses but they did not knew if it's compatible with Samsung, and did not want to
risk.
Has anyone knowledge of how can I resolve the problem? I who'd be very thankful...
08-11-2009, 07:25 AM   #2
I thought that you needed to go + rather than - for front focusing (e.g. +10)? I guess you tried it both ways though and confirmed it didn't work? The manual isn't very clear?
Anyway, I have the same setup, GX20 and Sigma 17-70mm and can confirm there are no compatibility issues with them. I did update the GX20 to firmware 1.01 before I took any pictures with it so it's possible that fixed something?
The first thing you need to prove is whether the problem is with your camera or lens. If they tested the lens with other Pentax cameras (which presumably they know are ok) then that would suggest the problem is with your GX20. Just because your kit lens works ok with it doesn't prove anything - that may be faulty as well. Do you have a third lens you can test the camera with?
Sorry I can't be anymore help but there are plenty of camera nerds on here so you should get a good answer soon
08-11-2009, 07:30 AM   #3
Moderator Emeritus
If the lens is quite new and came from a store, why not return it for a new one. It's possible that there is an element that is mis aligned and no amount of adjusting would fix that.
08-11-2009, 08:16 AM   #4
seliscan's Avatar
Thank you woodworm for the answer, I think that the camera may be faulty and I should send it back, but the problem is that the guys won't change the faulty camera if it works OK with the kit lens, they will just wash their hands because I bought the camera from another store than the lens.
The -10 i the settings moves the focus further from the subject, and does exactly what I needed but that wasn't enough (I used a calibration paper and tested all the possibilities), and I still have the front focus.
08-11-2009, 08:51 PM   #5
LeDave's Avatar
Wow, even if it works with the kit lens, it doesn't change the fact that they sold you a defective camera.
08-11-2009, 11:09 PM   #6
Sigma USA did the same to me when I sent it in for the second time, the asked me to send in my GX10 and told me one day latter that the lens worked perfect with two Pentax K10Ds. I posted it here about one year ago. Anyways I fought them hard and they said the would send mine back, but they send a new one to me that did not have the problem. The Samsungs and Pentax are the same. Its hard to know for sure who is telling the truth, or what is wrong. I would demand a replacement and or send it you Samsung to be checked.
08-11-2009, 11:21 PM   #7
Damn Brit
Guest
Can you post a couple of examples for people to look at?
Also include what settings you were using.
You never know, it might be something simple that you have or haven't done.
08-12-2009, 04:34 AM   #8
seliscan's Avatar
Today I received a message that after trying multiple prime lenses on my camera, they discovered that they worked also perfectly. So they've start calibrating the lens step by step and discovered that worked god at -6 only (very interesting because - 10 was not enough and a slit modification was resulting in major error; for example -5 or - 7)...
In the end they told package is on his way home and the system is working god; I hope they were right...
Another interesting fact is that I had a macro distance of only 1 cm instead of 20 (which was mentions on the lens) when I was trying to photograph Jules.
I'm puzzled, is it that hard to make something work properly from the beginning, or what? They should be ashamed that such problems exist at all and at least they can change the product immediately without so many cheep excuses...At least the guys from Pentax-Sigma were very polite and don their best, I can't tell the same thing about our Samsung representatives witch are INCOMPETENTS and wash their hands immediately!
Thank you for all the answers, in the end the guys from Pentax-Sigma representatives solved the problem .
11-18-2009, 06:58 PM   #9
theperception2008's Avatar
Location: Łódź, Poland and Riverside, California, U.S.A
QuoteOriginally posted by seliscan Quote
It seems that anytime you buy a third party lens, they have some focusing problems as a result of different cameras with different tolerances. I will most likely send in my tamron and gx-20 to get calibrated so they can work in unison :-)
bucharest, camera, dslr, gx-20, kit, lens, pentax, photography, samsung, samsung gx-20, sigma
Sigma 70-250 1:3.5-4.5 KA mount lens on Samsung GX20 DasModell Pentax SLR Lens Discussion 1 08-18-2009 12:19 PM
[Ask suggestion] betwen FA 50 f/2.8 with M 50 f/1.7 Aufa Pentax SLR Lens Discussion 4 03-10-2009 11:23 AM
Samsung GX-1S Firmware Update Problem Tim4Peace Pentax DSLR Discussion 1 04-03-2008 03:32 PM
For Sale - Sold: FS: Samsung GX10, Sigma 50-500mm (Bigma), Sigma 400mm AF chirpy Sold Items 4 03-24-2008 11:07 AM
All times are GMT -7. The time now is 03:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
