08-12-2009, 05:07 PM   #1
fillerupmac's Avatar
K7 - Is it smarter than me???
I thought Manual Mode should be just that - manual.
But when I alter the aperture, or the shutter speed, the camera seems to want to stay within a range, for example. it may only allow shutter speeds of 1/25 to 1/80, then go back to 1/25 instead of faster shutters. Or same with aperture, f4 to f8, then back to f4.
Is it trying to fit these into a usable range?? I might be shooting in very low light situations for example, but I want a closed aperture for DOF, and can extend the time.... but it won't let me...
Does this sound typical? Is there a work-around?
Thanks for tips / help
Al
08-12-2009, 05:13 PM   #2
pcarfan's Avatar
The only thing I can think of is, may be in the custom menu you had instructed the camera to do 'auto EV compensation'.
08-12-2009, 06:11 PM   #3
Yes, Auto EV compensation (Item 9 in the Custom menu) is meant to be an "Error Proof" setting for the camera which prevents the user from accidentally dialing a wrong exposure.
But it can be infuriating if you forgot that you set it ON. It does a similar job in Av and Tv modes. It will force the camera back to the Minimum or Maximum Aperture/Shutter speed which will allow a proper exposure.
Default is "OFF" but check if you may have accidentally set it "ON".
08-13-2009, 11:53 AM   #4
Thanks!
You've taken away one of my frustrations. It's been a good day.
PS: I have resolved to re-read the Magic Lantern guide to my K10D end to end. I think that I've forgotten what I didn't understand in the first place. (If Yogi Berra didn't say that, he should have.)
08-15-2009, 03:16 PM   #5
QuoteOriginally posted by pcarfan Quote
Nope Auto EV is OFF, the default.
Maybe the lens???? I was using a Tamron AF17-50 f2.8....
Al
08-15-2009, 03:27 PM   #6
Shashinki's Avatar
Your question: "K7 - Is it smarter than me???"
The answer is: "Yes it is. Be careful, make sure it doesn't sneak up on you while you are sleeping"
aperture, camera, dslr, f4, photography, shutter
Proof Pentaxians are Smarter than Canon owners Mike L Post Your Photos! 14 01-22-2009 06:18 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, part of our network of photo forums!
