Originally posted by fulcrumx29 Hi All,
Both the two copies of K-7 I got have intermittent screen flash problem. The problem just went out recently and don't know when will they come back. The problem is frequent during quick battery changes (from one to another body). Maybe it is due to frequent change of voltage (7.2 vs 0)?
Tony
Don't you switch off the camera before removing the battery ?
The voltage drop from turning it off using the On/Off switch is gradual, but if you forgot to switch it off....you may fry the circuits.
I once accidentally removed the batteries from a K100D without switching it off - it really went flaky after that and I had to do a reset to bring it back to normal.
