08-20-2009, 04:10 PM   #1
Mode switch fix for *iST-DL and possibly other models
For a while I've noticed that when my trusty old Vivitar 285 flash is mounted on the hotshoe of my *ist-DL, occasionally I get wildly overexposed photos. More recently I saw the camera revert to another mode during a Manual exposure astro photo. Later it got so bad that when I was in P mode it would jump into Autopicture, when I was in Aperture priority it would jump into Manual. Slight pressure or movement of the camera top was making the camera randomly jump into multiple modes.
A slight pressure on the "flash up" button occasionally cured it for a few minutes, but the issue made it impossible to rely upon to take or even review photos! The company I had my service plan through was out of business and repair options in Ireland are limited and expensive so I decided to try to fix it myself. If you try this, be aware that it is very risky and should only be attempted if you are experienced at this sort of thing and/or have written off the camera ;-)
The problem turned out to be a very slight residue (corrosion?) on the printed circuit contacts beneath the mode switch. A quick wipe with 97% isopropyl alcohol fixed it. The real trick is removing the top of the camera to get at the circuit board and putting it back in working order. Here is how I did it for the *ist-DL. A similar technique may be possible for *ist-D and other models. But the good seals in the K7 should make this kind of problem unlikely to occur, even here in rainy, windy, salty Ireland.
camera, circuit, dslr, ireland, jump, mode, mode switch, models, photography, pressure, switch
*ist DL mode dial problem? dalo Pentax DSLR Discussion 1 10-03-2010 12:32 PM
*ist DL doesn't always wake up from standby mode bonitap Pentax DSLR Discussion 2 06-25-2010 07:16 AM
Price of older models after introduction of new models? sterretje Pentax DSLR Discussion 5 01-22-2010 10:22 PM
*IST-DS shutter won't fire in AF mode Sigmoid Pentax DSLR Discussion 9 09-28-2009 02:26 PM
All times are GMT -7. The time now is 09:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
