08-21-2009, 06:08 PM   #1
Nick Siebers's Avatar
Shake reduction with Fish Eye adapter
Hello all -
I have a Samyang fish eye adapter that screws in to the front of a regular lens, giving 180 degree view and I believe multiplying the focal length by 0.15. I am still trying to get the hang of it. Today I was using it on a FA 50mm lens, and forgot to turn SR off at first. Thus, automatically it was set to 50mm. Later I noticed and turned it off. With manual lenses I had been entering the value (focal length x 0.15), which I would have guessed to be the correct thing to do.
BUT - the pictures with SR set at 50 were all much sharper than the pics with SR off. So now I am not sure what I should do moving forward. Anyone have this already figured out?
TIA, Nick
08-21-2009, 06:25 PM   #2
Banned
I have a 6.5mm F3.5 Opteka Fisheye lens and I set SR FL to 8mm because that is as low as SR FL could be set to.
08-21-2009, 06:32 PM   #3
Damn Brit
Guest
Leave it at fifty then. When you have a lens that doesn't coincide with the 'in camera' focal length numbers, it's always advisable to go under instead of over.
08-21-2009, 07:02 PM   #4
Do you like the Opteka? Thanks!!
08-21-2009, 07:36 PM   #5
Ah Gary, that's what's bugging me. I would think that having the SR set to 50 while the effective focal length was 7.5 would throw it way out of whack. I have seen that happen when I leave it at 500 for my mirror lens, and then use a regular 50mm prime. So why would having it set at 50 be better than none at all? Maybe it was just technical errors on my part. Ill have to try a test with a M 50 - SR at 50, 8 and off, all other settings the same. At some point!
08-21-2009, 09:52 PM   #6
Damn Brit
Guest
I'm confused now. In the original post you don't mention anything about setting SR to 8 which is the lowest value. You only mentioned it set to 50 or off. What happens when you set it to 8, any difference?
08-22-2009, 05:32 AM   #7
I was using an FA lens, so couldn't change the SR settings from 50. I'll dig out an M lens and try.
08-22-2009, 08:09 AM   #8
Banned
QuoteOriginally posted by stanleyk Quote
It's a great value for a 180 fisheye lens and I plan on doing some 360 panorama's with it in HDR mode etc. Everything from about 1 ft to infinity is in focus @8.
Samyang 8 mm f/3.5 Aspherical IF MC Fish-eye review - Introduction - Lenstip.com
Hayden Planetarium :: New York City :: 360 Degree Panoramic Photography, QTVR & Virtual Tours :: Sam Rohn
Afdeling Kust - Yachthavens
08-22-2009, 11:35 AM   #9
Well, I did test it, and it's pretty clear that 8mm is the way to go. Actually I couldn't see much difference between any of them outside at 1/60, but at 1/4 the difference is clear - don't use 50mm. So why did my other ones come out sharper with SR on at 50mm than off? Must have been my error.
SR=8mm
SR=50mm
SR off
50mm, adapter, camera, dslr, eye, fish, fish eye, length, lens, photography, sr
Nature shots with a junky fish-eye adapter rparmar Post Your Photos! 2 11-04-2010 05:26 AM
Pentax-A 16mm fish eye vs. 17mm Fish-eye-Takumar Nick Siebers Pentax SLR Lens Discussion 4 05-26-2010 03:51 PM
Aircraft fish-eye photo without fish-eye lens.... 7.62lew Post Your Photos! 16 05-17-2009 08:38 PM
Kenko Fish-Eye 180 adapter RioRico Pentax SLR Lens Discussion 4 04-03-2009 08:25 AM
Fish-eye versus non-fish-eye @ a similar focal length. Frakkas Pentax SLR Lens Discussion 5 07-19-2007 05:13 AM
All times are GMT -7. The time now is 07:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
