08-25-2009, 05:01 PM   #16
cardinal43's Avatar
QuoteOriginally posted by Mike Cash Quote
To me the most interesting and mysterious piece of gear I encountered while in the Navy was the Peri-Jet Eductor. The idea of pumping water into a flooded space to dewater it was something I never could have imagined.
That's because it was the Navy. I know you don't like emoticons, so I will just say...J/K. I served from 64-68 (but I was a radioman).
08-26-2009, 12:30 AM   #17
Not quite.
If you're moving fast enough, a hole in the bottom of the boat can actually allow water to drain out of the boat, with the water speeding by serving as a sort of eductor pump.
Venturi effect. Most very-low pressure vacuum pumps work on this principle.
08-26-2009, 11:08 AM   #18
Moderator PEG Judges
Kerrowdown's Avatar
But if boat aint moving, it sinks
Camera with cracked base aint weather sealed
08-27-2009, 07:39 PM   #19
Leave it to the military. That is one tough pump! Being on a naval vessel (I never have been) I am sure water pumps and fire hose valves are abundant. If a compartment floods and there is debris floating around a normal impeller type pump would need to be much larger, heavy, not so portable... to handle what this device can without worry of clog or hazardous chemicals it will just push it all out. Who would think of something like this.
Thanks for showing
08-27-2009, 07:51 PM   #20
QuoteOriginally posted by jct us101 Quote
I'm talking about the K10D problem.
It could, most of the cracks don't though. I had the the crack on my first GX10 and just cut a small piece of electrical tape and tightly put it on, worked great and lasted a long time before needing replacing.
But just do like the other poster said and order a new bottom plate from Pentax parts depts. Make sure it comes with the weather-sealing, if not get those as well. Pentax is very reasonable on the price for common service parts. I just ordered a rear LCD cover for my K20D at $2.60 and the two way tape for .60 cents. Shipping was $8 so I went ahead and ordered two of each may as well . Now I don't worry about my rear LCD cover. Both are very easy jobs.
08-28-2009, 09:52 AM   #21
QuoteOriginally posted by jamesm007 Quote
Where exactly is this Pentax parts department? Link? Phone number?
bottom plate, camera, dslr, photography
weather sealing houstonmacgregor Pentax SLR Lens Discussion 3 07-02-2010 03:00 PM
Weather Sealing... Snowvent Troubleshooting and Beginner Help 17 01-11-2010 04:22 PM
MX bottom plate compatibility RickM Pentax Film SLR Discussion 4 11-05-2009 04:28 PM
Weather Sealing... rkt Pentax SLR Lens Discussion 2 10-24-2009 05:10 AM
Cracked bottom plate on K20D slawek Pentax DSLR Discussion 6 07-27-2009 07:58 PM
All times are GMT -7. The time now is 08:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
