Have you tried using the multi-exposure mode to smooth the water and blur the clouds. Works without the huge filter and very slow shutter speeds. No waiting for dark frame subtraction or preview images.
Some restrictions apply, and your mileage may vary.
- Must use a tripod (but you were already doing that if your using long exposures)
- You should use a remote (wired or IR)
- You may only take a maximum of 9 frames (you can take as little as 2)
With camera on a tripod and set to take the image here is how you do it:
- Press the Menu button
- Navigate down to Multi-exposure
- Navigate right to select Multi-exposure
- Navigate right then down to the number of exposures, press OK to confirm
- Navigate down if you want to auto-adjust EV
- Press OK twice to exit menu
- Press the shutter release on the remote
- Each successive frame will be added to the next until you have taken the predetermined number of frames
- Once complete all frames will be saved as a single image.
5 to 9 frames of the same scene with clouds or other objects moving will blur them while stationary objects will be sharply in focus. You can take a series of images at more normal shutter speeds and then combine them to simulate the use of a neutral density filter.
