Originally posted by wll I have purchased a couple f cameras from e-bay as new... all these cameras have had ~240 shutter activations. is that about what you get on a new camera from B&H when you buy it.
These camera seem new, look new, have no blems and the lens mount is not scratched...
So does Pentax test each camera about 200+ times before it goes out.
Just curious.
wll
From what I understand of the manufacturing process of dSLRs - the AF system and Exposure metering on
every individual unit has to be tuned before it leaves the factory. The combination of mechanical and electronic components assembled often does not quite work to specification 1st time without adjustment.
Add to that routine QC tests to make sure all the main camera functions work properly.
Yes, I wouldn't be surprised if they do more than a hundred shutter actuations before its finally packed at the factory.
By way of example, if you buy a new TV, the picture tube may well have been turned on for a few hours of calibration and testing even before it leaves the factory....
