08-23-2009, 08:58 AM   #16
QuoteOriginally posted by Spock Quote
Anyone else have difficulty the removing SD card from a K7?
I did initially, but just doesn't seem to be a problem any more. Not sure why, if it is because I adapted or the card pops up more making it easier to remove. Regardless, just not an issue any more.
08-23-2009, 11:22 AM   #17
Use the thumbnail indentation at the top of the card.
Sounds like the same issue as with the K200D. Every SD card I have bought has a thumbnail indentation at the top of the card on the label side. You have to train yourself to use your thumbnail to extract the card. Since being alerted to this in the DPReview Pentax forum, I have been able to successfully extract the cards without flipping them across the room.
08-23-2009, 02:38 PM   #18
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by WalterGA Quote
Simple solution is to get a K20! No problems with my K20's sd cards!
08-23-2009, 06:57 PM   #19
Arpe's Avatar
Difficult? No.
Tricky? A little bit.
As someone above I grab it at the corners, not front/back.
08-24-2009, 12:17 AM   #20
Spock's Avatar
QuoteOriginally posted by Tom in Delaware Quote
Ha! That reminds me of an incident early in my digital photography days, when a 256MB SD card (expensive in those days) flipped out of my hands and slid under the skirting board to end up under the floorboards. Sometime in the future, archeologists will study my images to get an idea of what life was like in 2003.
camera, card, difficulty, dslr, k7, photography, sd
Problems removing SD card from my K-5 peerSr Pentax K-5 70 02-02-2012 12:01 PM
After removing dirt, what is this? Jimmymack Pentax DSLR Discussion 12 08-23-2010 04:13 PM
Difficulty with exp. comp wasim_altaf Troubleshooting and Beginner Help 15 07-22-2009 04:04 AM
Removing old pics wildman Site Suggestions and Help 2 03-25-2009 02:39 AM
The difficulty of buying tripods and Pentax Camera and Field Accessories 14 03-13-2007 12:04 AM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
