08-24-2009, 11:10 PM   #1
K2000 Noise,help
I have use several pentax DSLR, just changed my small DSLR *ist DL to the K2000. anyway, just tried some test pic at ISO 800 & ISO 1600, but i found the images are very noise compare to other Pentax DSLR like K10D, K20D or even the *ist DL. Is there anyway to tweak it for less noise at high ISO. thanx
08-24-2009, 11:40 PM   #2
QuoteOriginally posted by winglik Quote
I'm guessing that you're shooting JPEGs, and if so you just need to adjust the sharpening settings down a bit. In-camera sharpening will increase the appearance of noise.
08-25-2009, 12:01 AM   #3
KungPOW's Avatar
Low noise, high ISO pics hvae more to do with technique then the camera you use.
- shoot RAW
- Over expose a 1/2 to 1 stop and pull back the exposure in PP (look up "expose to the right")
- sharpen and conver to JPG in your computer, not you camera
08-25-2009, 04:38 AM   #4
Definitely shoot in RAW and use some kind of noise reduction software, like Noise Ninja or Noiseware. Also, as mentioned above, it is paramount that you hit your exposure right on. If you have to bring up your exposure, you will see lots of noise. I'd have to disagree on the K10 with regard to noise. It is barely useable up to iso 800. The older 6 megapixel cameras could easily be used to 1600 though...
08-25-2009, 04:44 AM   #5
when i first got my k2000, i noticed that as well, but as it turns out, it's the exposure.
make sure you expose propery. an underexposed shot will show much more noise
08-25-2009, 06:41 AM   #6
Ash
Community Manager
Ash's Avatar
Do post some examples, and try looking at your results without having had any PP applied to see if your software is just boosting exposure automatically (sometimes unnecessarily).
08-25-2009, 11:51 AM   #7
I also own a K2000 and get great ISO 1600 and very usable ISO 3200 shots. Ditto to all the above advice plus get an f2.8 or better prime lens.
08-25-2009, 11:58 AM   #8
Eruditass's Avatar
also check to see if shadow compensation or D-Range are on
08-25-2009, 12:13 PM   #9
I know this may be kinda obvious, but don't forget to turn on High ISO noise reduction. It's hidden in the menu, in one of the custom settings.
08-25-2009, 12:25 PM   #10
Marc Sabatella's Avatar
I'd suggest a side by side comaprison of the same scene shot with different cameras, same exposure settings, RAW. I think you'll find virtually no difference between cameras when comapring images at the same size. Most likely, any difference you are seeing is coming from differences in the JPEG settings you are using (including sharpening, noise reduction, and "D-range") between the cameras, also differences in exposure, lighting, or the scenes themsevles if you are comapring images you took with the K2000 against images taken of completely different scenes with completely different settings with the other cameras.
08-26-2009, 11:46 AM   #11
PentaxPZ's Avatar
I get little noise from my K-m....
and I shoot in a night club every friday with low ever changing lights!
few shots have noise but when shooting in red and blue light I expected some!
08-26-2009, 12:17 PM   #12
pcarfan's Avatar
Marc,
So are you saying that there will be virtually no differnece in noise between the k10D and the K20D, given the same scene etc.
Thank you.
08-26-2009, 08:31 PM   #13
Actually, the K10D seems noticeably worse than other models for whatever reason - mostly on account of the banding (vertical pattern noise) that it was prone to. The K2000 should outperform it, I would think. But again, it's really easy to get fooled by measurement error - using different JPEG settings on one camera versus another, etc.
08-27-2009, 02:29 AM   #14
pcarfan's Avatar
Actually, the K10D seems noticeably worse thn other model for whatever reason - mostly on account of the banding (vertical pattern noise) that it was prone to. The K2000 should outperform it, I would think. But again, it's really easy to get fooled by measurement error - using different JPEG settings on one camera versus another, etc.
Thanks...'getting fooled by jpeg', definitely learned that first hand when i got my K-7
08-27-2009, 03:31 PM   #15
A bit late, but I thought I'd chime in with my experience. I moved from a K100d to a K-m, and my first impression was, like the OP, that the K-m seemed really noisy. I was surprised to find that, when I tried taking photos side-by-side with the two cameras, the noise levels were actually pretty comparable. (Although the two cameras did seem to generate slightly different exposures, despite having the same settings and matching lenses/apertures/shutter speeds.)
One thing I did get from the experiment was an appreciation for how noisy JPEG is compared to RAW. I think this is worse on the K-m, although I might have been unconsciously biased by hearing the various accounts of how the K-m's JPEG engine is supposed to be lousy. Regardless, it prompted me to go out and buy some bigger SD cards (whose prices are still falling gratifyingly quickly) and start using RAW exclusively.
*ist, camera, dl, dslr, iso, k2000, noise, pentax, photography
K2000 NR WillCarney Pentax DSLR Discussion 1 01-26-2010 02:53 AM
K2000 Duane Pentax DSLR Discussion 6 12-20-2009 05:28 PM
Too much noise in KM/K2000 soalle Pentax DSLR Discussion 17 07-10-2009 05:06 PM
Strange noise coming from the K2000 pentaxNasson Pentax DSLR Discussion 16 02-13-2009 02:45 AM
cs3 noise filter vs. noise ninja vs. ??? reknelb Pentax DSLR Discussion 0 03-04-2008 04:55 PM
All times are GMT -7. The time now is 07:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
