Your cam should communicate with the flash no probs for wireless flash.
Have you done all of the following?:
mounted the flash on the hotshoe,
turned on the camera, then the flash,
set wireless flash mode on the camera (Ch 1),
set the flash to wireless mode (midway on the power switch),
confirmed Ch 1 on the flash using the R hand slider,
see that the test button light flickers,
depress the shutter half-way before dismounting the flash
dismount the flash and place in your desired location with a reasonable direct path from camera flash to IR sensor of the flash unit
flipped up the camera flash
fired away...
Sounds like an arduous task but when you get the hang of it, it only takes a few seconds...
