08-27-2009, 11:34 AM   #1
TAV max iso 400?
What am I missing? I got my K20D yesterday, and when i switch to TAV it wont adjust the iso past 400. Is there something in the custom menu i need to adjust? Thought i read the manual, but maybe i missed it. Thanks!
08-27-2009, 11:37 AM   #2
Driver3's Avatar
The max will be the same as the auto iso max. This is adjustable in the Fn menu.
08-27-2009, 01:19 PM   #3
hmm, my auto max is set to 3200 I believe. Ill have to look into this further. Thanks, and when I say it caps out at 400, I mean it hits 400 then starts blinking. If i keep going to where I'd expect a higher iso, I dont get one but instead an underdeveloped image.
08-27-2009, 03:06 PM   #4
Driver3's Avatar
If you press the Fn button and then press the right arrow key that takes you to iso.
Press the up arrow until auto is highlighted. The green bar down the scale tells you the max. The rear button lets you adjust it. That sets the max your iso will go before you run out of exposure parameter.
Also, if you are in Tav mode you don't have to put it in auto iso, it is already there. You can also set a minimum limit too.
I just tried it an my K20 just to make sure I wasn't talking through my hat.
08-27-2009, 05:39 PM   #5
Arpe's Avatar
I used TAv on my K20D up to 4500, so it can be done.
08-27-2009, 09:45 PM   #6
Thanks Driver3, that was absolutely it! Little bar on the side... Gotta love re learning how to use a camera! Thanks!
camera, dslr, iso, photography, tav
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 13 10-24-2010 03:30 PM
No ISO 51,200? Official Pentax site says 12,800 MAX! K-9 Pentax News and Rumors 6 09-20-2010 07:43 AM
ISO range in TAv mode? (K20d) Ratmagiclady Pentax DSLR Discussion 4 12-11-2009 12:06 PM
K20D Upper ISO Limitation in TAv Mode AdrianM Pentax DSLR Discussion 7 09-14-2008 04:17 AM
k20d auto ISO in TAv mode wiyum Pentax DSLR Discussion 10 08-13-2008 05:18 PM
All times are GMT -7. The time now is 04:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
