New Owner Here....
OK, first let me tell you I have the "Display Sensitivity" set to display the "frame count". But I only get this in "M" & "P" mode. All the other modes I get the ISO setting.
Now, more info...I don't have an AF lens yet..(not at this posting...Delivery of one will be in a few hours)..I have mounted a Pentax "A" 50mm lens. And the Body is on MF with SR set for a 50mm lens.
I also have the Back Wheel set to change ISO or Shutter Speed depending on the options available for any particular mode I have set.
Am I missing something, or, does the "Display Sensitivity" control work on "All" the modes only with "AF" lens mounted ??
EDIT:
OK, Got the Sigma 70-300 APO, And I made sure that the "Display Sensitivity" option is on "OFF" (option 1)...I still get the Frame count with "M" & "P" mode...Is this how it works?..I thought the "Display Sensitivity" option would default one way or the other...not a combination of both...
I am OK with that, if that the way it is..Can't find more info in the manual yet.
