I took some time to directly compare my old k10 with a borrowed k7. While editing photos with the k7 for the first time a while back, I felt that the images looked exceptionally noisy. I wanted to empirically determine how much the ISO performance differed.
Take a look at what I found:
Both cameras were reset to factory settings and placed in full manual on a tripod, using the same lens and identical exposure settings. I shot RAW DNG and did no editing at all, except the resampling.
It looks like at 100%, the k7 is definitely noisier than the k10, but if you resample the k7 down to the k10's resolution, it's far better.
And one thing that I find weird: the DNG RAW files from the k10 are 16.2 Mb. The DNG RAW files from the K7 are 16.3 Mb. So the K7 must be using higher compression. That would be ok if it was lossless, but doesn't the grain in these sample images look alot like an over compressed Jpeg? Are these RAW files actually using lossy compression?? I sure hope not!
If there's anyone out there who's concerned about the K7 noise performance, this should be interesting to you.
