08-31-2009, 02:54 PM   #1
Liveview depletes battery VERY quickly. [K-7]
on my K-7, let's say i have 2/3 of the battery left...i can only use the live-view for 20-30 seconds, maybe take 4 or 5 pictures before my camera shuts down and displays the 'Battery Depleted'.
I switch the power to the 'off' position and immediately back 'on' and i'll either still have 2/3 battery remaining or it will drop to 1/3 battery.
if i have 1/3 battery i literally cannot use the live-view for more than 5-10 seconds before the camera powers down with the 'Battery Depleted' message. I turn the camera off then back on...i have my 1/3 battery left still.
Eventually it gets to the point where i hit the LV button and my camera turns off almost INSTANTLY.
if i do it a few times it'll drain the battery right to the 0/3 position, still allowing the camera to turn on but the red empty battery displays on the info screen, which from there it'll slowly die until i can't turn it on anymore. [flashing 0/3 battery symbol]
i haven't tried how long i can use the LV on a 100% full charge but i can't imagine it being more than 2-3 minutes with 10-15 pictures before i start getting the auto-off and battery depleted message again.
is this normal? please tell me it isn't...
08-31-2009, 02:58 PM   #2
Damn Brit
Guest
The battery indicator hasn't been that accurate on DSLR's and Live View does use a lot of juice. Do you have SR off when using Live View? That will add to the burden if you have it on.
Maybe you have a faulty battery.
I don't think anyone has had a K-7 long enough yet to really know what is normal.
08-31-2009, 03:22 PM   #3
Nass's Avatar
That seems weird - I was toggling between live view and TTL for at least an hr today, no probs at all. Mind you it was fully charged when I started, but still, total live view time must have been a good 10 mins or so at least (profoundly unscientific guess).
08-31-2009, 05:09 PM   #4
Wheatfield's Avatar
Pentax is still noy using smart battery technology. When your battery indicator is showing one dot off charged, the battery is pretty near dead.
I was out shooting yesterday and noted that my battery indicator was showing 2 dots. The camera changed batteries to the in body one within 60 shots and was indicating a dead grip battery.
The battery indicator is not linear.
08-31-2009, 06:56 PM   #5
KungPOW's Avatar
huh...
I thought the reason Pentax went to a battery with three terminals was to allow for better read on the charge remaining.
Maybe I'm thinking of something else.
08-31-2009, 07:26 PM   #6
Lowell Goudge's Avatar
The problem is that no matter how you measure it, battery capacity under live view conditions is not the same as capacity under slr conditions.
with live view, sensor is powered 100% of the time, mirror is held up, LCD is on, and focusing is running full time.
that is a lot different than running the metering with the back LCD off.
08-31-2009, 07:51 PM   #7
My observations on the K-7's battery capacity.
a) Purely still photography - very decent capacity. I get 550-700 shots depending on whether I use the on-board flash and do a lot of reviewing.
b) LiveView / Video with a fully charged battery. OK, I've never had it shut down due to low battery. Of course, I have been careful to control the length of continuous LV/Video shooting - I try to avoid overheating the sensor. But the cummulative total time is quite decent more than 10-15 minutes without showing any battery depletion.
c) Live View with a partially depleted battery (icon showing less than full charge) - the camera will power down, "Battery Depleted", even though there's plenty of power left for dozens or even 100 more still photographs.
I think it has more to do with how the battery power management logic interpretes the power drain coming from LiveView rather than absolute battery capacity.
My workaround - make sure your battery is freshly charged, or at least showing all bars charged on the icon, you'll get a decent amount of LiveView / Video work from the battery.
08-31-2009, 07:54 PM   #8
TheTenaciousOne's Avatar
Ive had this problem to. Ended up just not using live view but yea. Never really liked it on a DSLR anyway
08-31-2009, 08:15 PM   #9
meh...
thanks for the replies guys!
09-01-2009, 01:21 AM   #10
I tend to think that this is a battery conditioning situation. The batteries need a number of depletion/charge cycles before they will charge to full capacity. The K-7 is too new for most to owners to have gone through this yet. . .
Scott
09-01-2009, 01:46 AM   #11
falconeye's Avatar
QuoteOriginally posted by PNTXFTW12 Quote
When I used the K-7 to record continuous video for about 30 min, I depleted only a fraction of the battery. LV alone would consume even less power.
So, LV can probably be used for hours before the battery is depleted.
However, if you use LV for every shot and leave it on until auto shut-off after 5 minutes, then you end up with a couple of dozen shots only.
09-01-2009, 05:27 AM   #12
Wheatfield's Avatar
QuoteOriginally posted by snostorm Quote
Scott
My first full charge after buying my K-7 gave me over 1600 exposures with no deflection of the battery meter. However, once the meter deflects off "full" the battery goes out very quickly.
battery, camera, displays, dslr, live-view, lv, message, photography, pictures, position
My thoughts on quickly testing the K7 paulsoucy Pentax DSLR Discussion 55 11-14-2009 03:37 PM
How do you change your lens quickly? Anya Troubleshooting and Beginner Help 5 04-24-2009 11:08 AM
Help me out quickly!! losecontrol Pentax DSLR Discussion 36 02-06-2009 05:02 AM
2 myths i would like clearing up quickly please... Isaac314 Pentax DSLR Discussion 9 12-09-2008 02:57 PM
Had to catch this guy quickly siric Photo Critique 4 07-15-2008 06:43 AM
All times are GMT -7. The time now is 10:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
