Originally posted by Rico It states: Under the light to measure the white balance, fully display a white sheet of paper in the viewfinder or select a white area as the subject. Using a neutral or gray card will not work when adjusting white balance manually as described by the owners manual.
Note that the second sentence ("Using a neutral or...") is not from the manual.
As a poster wrote in this thread, for the purpose of white balance, "white" is the same as "neutral gray."
In fact, in my experience, a piece of a neutral gray card (the 18% used in the old film days) is better than a white sheet of paper. Why? Because when it's too bright, our eyes can not distinguish slightly different shades of white. Many "pure white" surfaces actually contain a tint of blue.
The gray card also helps in metering.
