09-05-2009, 08:35 AM   #1
TakeshiKovacs's Avatar
exposure metering
New K-7 owner here, I'm generally quite happy with it. However, I'm not sure what the problem is, but metering between the viewfinder and the lcd is vastly different. I realize the lcd displays more stops, but that's not the issue.
For example, say I'm metering a scene and the lcd shows -2ev, the viewfinder says it's 1 stop overexposed. The lcd shows the 'correct' metering -- it's to the point where I can't seem to trust what is shown in the viewfinder. It's unacceptable to me to have to rely on the lcd, as it makes composing shots a pain if I'm not using Live View (which is about 95% of the time).
Does that make any sense or am I crazy?
09-05-2009, 10:37 AM   #2
So far, I've found the E/V showing in the Viewfinder, the top LCD, rear LCD and also Liveview (if turned on) all match.
Check to make sure its not the Electronic level you are showing in the Viewfinder and Top LCD.
The Rear LCD always shows E/V when in Manual mode.
09-05-2009, 11:27 AM   #3
DAZ
DAZ's Avatar
QuoteOriginally posted by TakeshiKovacs Quote
If you move your eye from the viewfinder this will let light in from the back and could change the metering. You need to cover the viewfinder if you are going to look at the LCD.
DAZ
09-06-2009, 09:58 AM   #4
QuoteOriginally posted by kittykat46 Quote
My bad, I didn't RTFM. Thanks.
Does anyone ever use the electronic level?
09-06-2009, 10:12 AM   #5
Senior Moderator
Nass's Avatar
Occasionally - but I often later regret having been a slave to gravity rather than to the subject of the photograph
camera, dslr, lcd, photography, viewfinder
Stop Down Metering With The Green Button: Wrong Exposure Recomendations Obs Troubleshooting and Beginner Help 55 03-27-2015 09:39 AM
km exposure metering newf6401 Troubleshooting and Beginner Help 2 10-13-2010 05:33 AM
Exposure Metering Timer samiam Pentax DSLR Discussion 11 08-13-2009 10:19 AM
K20D exposure metering accuracy Andrews Pentax DSLR Discussion 3 05-18-2008 07:18 AM
Exposure metering with K10D Workingdog Pentax DSLR Discussion 22 03-08-2008 04:19 PM
All times are GMT -7. The time now is 02:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
