The metering issues you experienced with manual lenses the K10D that were solved with the focus screen change are unqiue to that model and the K20D. None of the other models have these problems. So while I'm not sure if the D and DS screens are the same, they both work correctly for metering, as do the DL and K100D screens, which are definitely different from the DS.
BTW, with the D, I think you'll need to make sure you have the latest firmware in order to get manual lenses to meter at all. I'd guess most of the one you find used would already have that done, and even if not, it's probably still possible to get the firmware update, but you might want to look into that.
