Originally posted by Stratario The shim looks like a very wide "U" It is installed as an inverse "U". The missing side goes on the bottom where the hinge is.
Imade my own shims from plastic film that in the old days was used for overhead projections. That was too thin. So I cut narrow strips of sticky lables and stuck one layer of it to the plastic film. Now I have perfect manual focus.
Hope this helps.
I am a bit confused with the terminology: it is installed as a inverse U when the focus screen bracket is down or when it is up and you are looking with it closed? The hinge is the part that pivots closer to the LCD, and not the lock mechanism that is closer to the mount?, right?
Originally posted by eyou bottom is the back of the camera so the long single side should be closer to the lens mount
I believe I interpreted this backwards earlier, maybe that was the reason I was front focusing like crazy on my 1.7 lens..?
