Originally posted by KFrog I like the collection you have there. I don't have any Limited lenses but I did rent the 35mm Ltd. Macro a while back and I just loved it. I wanted to pick one up but the $$$ was a bit much. That's when I turned to Takumars. I now have eight in my collection.
Takumar Collection on Flickr - Photo Sharing!
For what I've spent on them I might have been able to get two Limiteds
. I still want at least one though...
This makes a lot of sence. The feeling you get from the limiteds and the takumars have a lot in common: build quality and small size. When I've been carying the Super Tak 105mm with me as a 4th limited they fit so well together that I have to remind me that it has not autofocus.
If you are to pick one limited, the DA35 is probably a good choise. It is as sharp at infinity as it is as a macro and work well as a general normal lens, with the limitations of the speed, but it is still faster than a kit zoom. The 70ltd is not the best portrait lens I've used, but it is certainly the most portrait IQ per kilogram I've ever had. Amazingly small and with a angle of view like a 105mm on a film camera. The 21 is still a wow experience since I've not had it for so long.
Given that the K-7 is supposed to speed up screw drive focus a lot I'm really interested in how these lenses will behave on this new body.
Originally posted by pcarfan How do you like the 135/2.5? (sorry for the hijack). Which are your favorites?
Pentax have built 135mm lenses with 8 different optical solutions with numerous cosmetical, auto-connection, or coating versions since m37 over m42 to K, KA and FA mounts.
I would rate the Pentax/Takumar lenses that I have used enough to judge according to optical performance:
1) SMC Pentax-A* 135mm f1.8 (7:6 lenses)
2) SMC Pentax 135mm f2.5 = SMC Takumar 135mm f2.5 (6:6 lenses)
3) SMC Pentax-FA 135mm f2.8 = SMC Pentax-F 135mm f2.8 (8:7 lenses) (only with AF, but very fast AF)
4) SMC Pentax-M 135mm f3.5 (5:5 lenses) (the smallest K if this is your priority)
5) SMC Pentax 135mm f3.5 = SMC Takumar 135mm f3.5 = Super Takumar 135mm f3.5 (4:4 lenses)
6) SMC Pentax-A 135mm f2.8 = Takumar (bayonett) 135mm f2.5 = Takumar bayonett 135mm f2.8 (4:4 lenses, different configuration)
Note that there are SMC Taks/Super-Taks 135mm f2.5 with a 5:4 lens congifuration, which I don't know how they rate. The early Takumar 135mm f3.5 where a 5:4 solution.
So I recon you ask about number 2 on this list. Yes, that is a very nice lens, and I use it quite a lot when I don't dare to cary around the 20 times more expensive A*. You can find a set on my flickr with pictures with this lens if you are interrested.
Originally posted by the swede Old lenses with the K-7 is realy fun! And it looks good. I think the K-7 looks kinda retro. It would be realy interesting to se if they continued on that path making the next body even more edgy but maintainin the comfortable grip.
To keep topic: The first thing i tried with my K-7 was my mothers old Chinon 50 1,9. It works great and so easy to meter with the green button.
I've heard that the stop down meetering with the K-7 is more exact (less need for exposure compensation), than with previous cameras. Can you confirm?
