Originally posted by LScrabeck Have a problem with my K100. In the viewfinder the alignment lines are tilted to the right with respect to the viewfinder itself.
Grab a quick shot with the camera level and the viewfinder aligned to the horizon the photo is tilted downward to the right a few degrees.
Taking care to align the horizon to the lines makes the photo correct but I have to tilt the camera to the left from level a few degrees.
Any ideas as to what is out of alignment in the camera and what it takes to repair it?
Any input would be appreciated--Thanks
Out of curiosity did you determine the tilt using a bubble level on the camera?
Reason being to determine if it was the sensor tilted or just the focus screen lines.
this is a problem that has plagued DSLR's for some time......
One final performance note: the viewfinder mask on my D50 is 0.6 degrees off from what it should be. Line something up with the bottom of the viewfinder frame and you'll be running Rotate Arbitrary in Photoshop a lot. I've yet to see a Nikon viewfinder that's perfect (curiously, they all seem to give you images that run downhill right), but my D50's is the worst of the bunch to date. Nikon D50 Review by Thom Hogan
