09-12-2009, 10:51 AM   #1
K10D Viewing Screen
Occasionally when I am viewing my shots on my K10D view screen and I'm either scrolling thru shots or trying to zoom in on a shot, the screen turns off. I turn it back on and try it again and it'll do the same thing. It doesn't do this all the time but I'd prefer if it never did it. Has anyone else had this problem?
09-12-2009, 12:10 PM   #2
jimH's Avatar
QuoteOriginally posted by FishrOfGrizz Quote
It happens to me a lot. I blame it on my finger brushing the shutter release button which will cause the display to shut off. Try it purposely on your camera and see if that isn't what's causing your problem.
09-12-2009, 01:23 PM   #3
Ash
Community Manager
Ash's Avatar
Then change the way you hold the camera while reviewing your photos...
09-13-2009, 04:20 AM   #4
fishy's Avatar
do you use a grip? Happens to me a lot...
09-13-2009, 06:39 AM   #5
jimH's Avatar
QuoteOriginally posted by fishy Quote
Typically hold the camera by the grip as you would to shoot a picture. It's the safest way for me to hold the camera. Since I know what causes the problem, I try to avoid hovering my trigger finger over the shutter release button. At any rate, it's no big issue, nothing wrong with the camera, it's just a little inconvenience. A little attention to the cause takes care of the issue.
09-29-2009, 07:42 PM   #6
I'm just getting around to checking my posts on this site so my apologies for not responding sooner. Much obliged for the suggestions. I haven't tested these theories yet but they make sense and I hadn't even considered that as a possibility.
Thank you
camera, dslr, k10d, photography, screen, shots
Viewing a 8" x 12" photo on screen full size raider Digital Processing, Software, and Printing 21 02-22-2010 07:36 PM
Correct viewing angle for LCD screen? Graham67 Digital Processing, Software, and Printing 2 10-31-2009 08:56 PM
Split screen viewing limitation qestion winglik Pentax DSLR Discussion 9 06-11-2009 04:05 AM
Pentax K10D question: viewing photos IsaacSteiner Pentax DSLR Discussion 14 04-01-2009 05:44 AM
K10D screen karq Pentax DSLR Discussion 9 10-28-2008 02:10 PM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, part of our network of photo forums!
