Originally posted by dwinnert I am new to the K10D so bare with me.
I am using the 40 Limited .
If I choose auto focus point and it selects an area to focus on, it never seems to be spot on with it's chosen focus point. Almost like there is a little BF/FF or the highlighted focus point is really not the one the camera is using.
If I manually choose the focus point...it is tack sharp.
This only seems to be an issue when I am in the 3-4' range. Farther shots always seem to properly focus on the auto chosen focus point.
Anyone else see this?
Thanks.
Hi dwinnert,
I assume you were doing your indoor shooting, the camera's green full auto focusing system is difficult to focus under indoor low light, I suggest that you turn the focus selection gear dial to SEL, then select the center focus point or any focus point you wish by pressing any of the 4 arrows, it will focus much quicker for you because you force the camera to focus where you want it to. If the indoor lighting is extremely uneven, like some ballroom or banquet room, I turned the metering ring to center metering, force the camera only meter at the center where I want it to meter, smaller metering area, less confusion.
I like to leave it at the center after I moved to SEL, because if I need to recompose, all I have to do just keep my finger halfway press after focus locked, then move the camera a little to the left or right, then shoot, it works perfectly for me. But you need to go to the menu camera setting section, there are 6 pages there, select page 2 or 2nd screen, select ON at the "AE-L with AF Locked" line, by default Pentax sets it OFF. IF you don't change the setting, you'll have difficult time to recompose your shot, the view finder will blink because the AE is not locked with focus.
Well, I hope it works for you, like one of those commercial...."Try it, you will like it". If you start thinking about it, that is why the K10D comes with 2 easy access metering dial and focus dial where your right thumb and left finger can reach easily.... That is another reason I bought mine other than ATV mode and SR.
