05-22-2007, 02:29 PM   #1
Trub
Guest
K10D and ISO above 200
Maybe I'm doing something wrong, but when I shoot @ ISO 200 and above, the I get this weird streaking going from top to bottom. It's more noticable @ 400 and above. I was wondering if anyone else has seen this before?
05-22-2007, 02:30 PM   #2
Could you post a sample shot of the problem? It might be banding, but it could also be regular noise...
05-22-2007, 02:44 PM   #3
Trub
Guest
QuoteOriginally posted by Mo Quote
I'm at work right now and don't have access to them right now but it's not noise. Banding is a good description of what is happening. I was at a rock concert and the lighting was up and down to go with the music. I got some good pictures, but some had what would best be described as banding. Can you give me some more info on it and how to avoid it?
Here is one of the better one's but in the RAW file there was some banding. I'll post a really bad one once I get home tonight.
05-22-2007, 03:00 PM   #4
To me it looks like shadows from the curtain behind her. There is a curtain behind her right? If not, tell everyone it's a curtain cause that's what it looks like (at least to me).
05-22-2007, 03:18 PM   #5
It's not banding, not in the usual sense anyway. I have to agree that it looks like a curtain. Certainly nothing I have seen in my images.
05-22-2007, 03:19 PM   #6
Trub
Guest
After looking up the definition of banding, it's clearly not that. I guess the only way to describe it is to post a picture. I'll have to do it when I get home though.
05-22-2007, 03:21 PM   #7
Trub
Guest
QuoteOriginally posted by davemdsn Quote
This is one of the good ones and it's not full size. When I get home and post a bad one, you'll clearly see it and go "WTF!"
05-22-2007, 03:36 PM   #8
stewart_photo's Avatar
I agree with CJ. All I see is a navy blue curtain with no obvious banding in her shirt, face, or hair. The same with the microphone and boom arm.
On another note, the image has a strong blue tint overall, even in the black microphone setup (once owned this setup, so know it's black). Cannot decide if this was intentional (blue stage lights or editing) or the result of incorrect white balance. Finally, I personally would edit out the bright spot in her hair from the earring since it's not immediately obvious that's what it is. Competent picture otherwise, though.
stewart
05-22-2007, 08:13 PM   #9
Trub
Guest
Ok here's an ugly one. There was an uglier one, but I deleted it because it was ugly! But this one is pretty bad. Now I was shooting wide open because it was dark and there was a fog machine so I don't know what happened, maybe too much light at too high of an ISO?
05-22-2007, 08:32 PM   #10
That's the famed "stop complaining" "Only exists in underexposed photos" "Some people actually USE their cameras instead of whining" "I don't get it on MY camera" "Would you please shut up already, your constant negativity gets so annoying" "There is nothing wrong in that picture, but please buy our replacement for the K10D next year that fixes this completely" .......VPN.
05-22-2007, 08:47 PM   #11
QuoteOriginally posted by mutley Quote
Come on, tell us how you really feel.
How about a dose of reality, high ISO has always sucked and always will. The images shown on this thread are not pretty, but they are pretty much what I would expect from high ISO. Using high ISO doesn't really turn up the sensors sensitivity to light, it only boosts the signal, which amplifies any latent issues (exposure, shadow density, et al). The IS vpn in the second image. It is fixable, and not with a new camera or a firmware update. It is fixable with corrections in exposure and color balance (the image is quite blue, which is the channel that the K10D vpn is in).
Another thing, have you tried printing it? Noise is usually worse on a monitor than it is in a print.
05-22-2007, 08:57 PM   #12
In this picture, I think you're seeing a combination of the stage background, objects on the stage reflecting lights onto that background, image noise from the high ISO, and some lens flare. I don't see any evidence of streaking or banding in the jacket, face, or hair of the singer. The only thing I see there is the blue blob under the sideburn - most likely unrelated lens flare. Software or a plugin to reduce image noise might improve the background somewhat, but the lens flare and reflections will be more difficult to remove (not impossible, but some software editing required). Another option is to simply cut the subject out and paste him on a cleaner background.
stewart
06-13-2007, 10:56 AM   #13
Trub
Guest
This picture is what I'm talking about. The first picture is the over all picture. The second is a crop of the actual size (1:1) of the bottom of the cup where the shadow starts. You can see the artifacting which looks like gainey blue-ish lines going vertically.
06-13-2007, 12:40 PM   #14
That's normal at high ISO for the K10D. I just try to avoid going above ISO 800 if all possible. On screen at 100%, you probably see more color noise. When you print, the noise is barely noticeable. Don't pixel peep too much. Just go out and enjoy taking photos. Pentax sensor is known for now not to be as free from noise as the Canon CMOS sensor. That's a given so why worry?
06-13-2007, 02:07 PM   #15
Trub
Guest
QuoteOriginally posted by neighhoma Quote
I forgot to say that it was taken at ISO 100! And I have to "pixel peep" for stock photography. The inspectors at iStockphoto.com can see noise/artifacting from a mile away.
So the Canon sensors do a better job when it comes to less noise?
camera, dslr, iso, photography
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
Iso 200 pingflood Photographic Technique 49 03-30-2009 07:29 PM
iso 100 or iso 200 kiwao Pentax DSLR Discussion 8 03-05-2009 01:02 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
Tests iso 200 to iso 3200 with k100d Deni Post Your Photos! 0 06-20-2007 05:17 AM
All times are GMT -7. The time now is 10:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
