11-04-2009, 01:03 PM   #46
Eruditass's Avatar
You can assign the green button, next to your right index finger, to do center-AF point.
When it is set up like this, you push that with your index finger, then push the 4-way pad with your thumb, and focus, no extra button pushing. You have a maximum of 3 quick button pushes to reach any focus point (green, and 2 direction pushes), and you always know where you are when you push the green button. You don't have to push OK or anything.
Worked pretty well for some action shots I was taking.
As for changing the metering method, I find it pretty simple especially now that the e-dial can change the setting when hovering over it. Hit info, go to metering, move e-dial. To change again, hit info, move e-dial. Works with any setting including auto-focus mode (though I pretty much only use select AF point). If you set green button to center focus, using the e-dial switches between modes. If you set green button to center focus, using the e-dial switches between modes. Then hit info and its still on metering mode, use e-dial to change that.
11-04-2009, 01:42 PM   #47
Part two of the story:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/78680-k-x-first-impressions.html
af, camera, dslr, k-x, k10d, photography
For Sale - Sold: K10D w/ 3 Extra Batteries, DVD Tutorial, K10D Book! ksignorini Sold Items 2 08-28-2008 08:24 PM
For Sale - Sold: FS: New K10D battery, K10D book sven Sold Items 2 12-17-2007 12:42 AM
All times are GMT -7. The time now is 09:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
