Originally posted by jimH I'd like to find out how common it is to have the Shake Reduction Lever break off on the K10D. I've had the problem and I know of one other. Has anyone else out there had that problem?
I have had no problems with either my GX10 and now my K20D but! Its a well known problem and well documented on forums from other owners. The problem was pretty serious when the K10D first came out; in latter production runs Pentax fixed the problem. It was a QC issue with the switch from a parts supplier, they would fall off with just a touch! The K10D also had some bodies that had a hairline crack on the bottom plate (back right corner holding the K10 normal) this was also fixed with latter runs. My GX10 did have the hairline crack! lucky it died and my replacement GX10 from Samsung did not have it.
Just do a search on dpreview and you will have a ton of hits.
