Originally posted by potatolicious Can you elaborate more on this? I would have thought if you preferred wides you'd go for the DA* 16-50 - get quality at the focal lengths you use most? Same for teles: go for the DA* on the lens you'd use most.
Not if you use wides the most, but what you use while hiking. The DA* 16-50 is 260% heavier and 80% larger than the DA 18-55 WR; the DA* 50-135 is 333% heavier and 91% larger than the DA 50-200 WR. Although the difference is only about one pound, that matters if you are climbing 6000 feet in a day. Or, if I'm thinking about carrying the DA*16-50, I'd rather carry both DA 18-55 and 50-200 WR for about 3/4ths of the weight.
Of course, that assumes that hiking is the first priority. Carrying the extra weight isn't an issue if photography is paramount.
Giving it a second thought, I'd suggest: DA 18-55 WR and DA* 50-135. The 18-55 is small, light, and good for hiking. The 50-135 is good for portraiture and low-light, staged events. The DA* 16-50 is somewhat better than the DA 18-55, but the DA* 50-135 is quite a bit better than the DA 50-200.
Personally, if I had to start over with lenses and had a ~$1000 budget--and was limited to new lenses--I'd go for an DA18-55 ($150), DA70Ltd ($550), and DA40Ltd ($340). That says something about my personal preferences against large zooms.
