Originally posted by The Rock Well, it is good that You wrote that You find the colors of k20 better than k10.
Imaging resource does a series of objective tests of cameras.
There is nothing wrong if You like colors of k20 better. It is important that k10 more accurately represents colors than k20.
See the tests for yourself if you think im lying or thinking out.
Regards.
The default color mode for the K10D was natural, for the K20D its bright. This is why they measured different.
Now in RAW I don't think the K20D is better than any camera but here is what Ned B says about the color of the K20D versus the K10D, I guess I was wrong he says CMOS does make produce different color! Now is this for RAW as well, I don't know, but personal I still believe its just a WB difference.
"There are subtle differences in the "color" or tone of an image captured by a CMOS vs a CCD sensor. I've been so busy lately that I haven't been able to do any substantial tests to show the differences between the K10D and K20D. The two images below are only intended to show under fairly controlled lighting how the CMOS sensor in the K20D will generally produce a slightly warmer tone image than the CCD based K10D.
You'll probably see a more noticeable difference in the way the K20D records skin tones, and depending on the type of lighting, it produces a smoother almost buttery look. If anyone currently has both the K10D and K20D, it might be a great service to your fellow Pentaxians to provide better samples than my couch to show these differences in tone."
