09-25-2009, 05:50 PM   #1
Shake reduction K10D
Is the shake reduction function still operational on my K10D?
When I go to the 'menu' function in 'rec mode' and scroll down to 'shake reduction' the words shake reduction are visible but are opagued out. If I switch between shake reduction on/off there appears to be no change in the script "shake reduction" on the menu screen.
I cannot recall if this is as it was when the camera was purchased or what I am seeing is essentially an error message
If someone could check their K10D and let me know what they see it would be appreciated.
09-25-2009, 06:20 PM   #2
MSM
MSM's Avatar
Troutman: The SR control is still functional and controlled from the back of the camera. The menu item you are referring to is only used if you need to set the focal length of the lens because it is an older lens such as the M42 mounts and the K, M, A series lenses. If you are using say an FA or DA mount then the Focal length info is already sent to the camera and the menu item remains opaque.
09-25-2009, 07:03 PM   #3
MSM
Thanks for the quick reply and explanation.
09-25-2009, 07:40 PM   #4
jmc7104's Avatar
Also as you are looking through the view finder there should be a little hand symbol displayed os the left side of the screen if sr is engaged, it takes a couple of seconds to activate on half press of shutter button. jim
09-25-2009, 08:26 PM   #5
jmc7104: thanks for the input
09-26-2009, 11:11 AM   #6
i almost died when i thought my SR was acting up. fortunately it was the same situation you described
09-26-2009, 12:46 PM   #7
QuoteOriginally posted by adamkean Quote
adamkean: I had the same sinking feeling. Nice to have the question answered so quickly and clearly. Great forum!
camera, dslr, function, k10d, photography, reduction, shake, shake reduction
K10D Shake Reduction Help blank Pentax DSLR Discussion 1 12-24-2008 07:11 AM
k10d and shake reduction? silent_eyes Pentax DSLR Discussion 14 08-14-2008 03:33 PM
K20D / K10D shake reduction wonderer Pentax DSLR Discussion 16 06-25-2008 01:39 PM
K10d shake reduction Dave Lee Pentax DSLR Discussion 17 06-07-2007 10:56 AM
K10D Shake Reduction and Tripod Ian Mc Pentax DSLR Discussion 9 12-31-2006 04:50 AM
All times are GMT -7. The time now is 08:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
