09-27-2009, 03:06 AM   #1
DanielT74's Avatar
K20D shake reduction problem?
Hi Folks,
I've just upgraded from K10D and what a beauty this is. Except I don't think the shake reduction is working.
On K10D it made quite a difference shooting with or without the SR, now I can't tell the difference at all. I am wondering if there is a special trick to activating the SR or if somewhere deep in the menu, it's been deactivated, though I haven't found anything at all.
Has anyone had a similar problem or has any relevant ideas?
09-27-2009, 05:23 AM   #2
David's Avatar
QuoteOriginally posted by DanielT74 Quote
Hi Folks,
How about some samples with exif data.
09-27-2009, 09:02 AM   #3
Marc Sabatella's Avatar
One possibility - you aren't half-pressing the shutter long enough to enable SR. The K20D focuses just enough faster than the K10D that simply punching the shutter won't necessarily work - the camera may focus and take a picture before SR is ready. So definitely be in the habit of half-pressing and waiting for the hand icon to light up before taking the picture.
10-02-2009, 06:24 AM   #4
DanielT74's Avatar
Yep, I think that was it! Now that I am watching for the hand icon to appear, I see that it takes a little while after the lens has focused and a couple of quick comparisons (with and without the SR) look right.
Thank you for your help!!!
10-02-2009, 10:32 AM   #5
if you root around in the settings you will see you can decouple the AF from the half-press on the shutter button, but a half press will still start the SR. I use the AF button on the back to focus and keep the shutter button half pressed to avoid any lag time waiting for the SR to get going. It's not so needed when shooting static objects but fr action shots it really helps a lot.
FYI, to focus you will need to either manual focus or use the AF button itself.
camera, dslr, k10d, photography, reduction, shake, sr
Shake Reduction/Over Exposed Images Problem Jeff Lowe Pentax DSLR Discussion 20 06-19-2010 09:05 AM
Pentax K-7 Shake reduction problem raywheeler Pentax DSLR Discussion 34 12-01-2009 09:30 AM
K100D Super Shake Reduction problem lochest Pentax DSLR Discussion 2 10-15-2009 08:38 PM
K20D - Cant tell if shake reduction is on? designinme_1976 Pentax DSLR Discussion 7 06-17-2009 07:39 PM
K20d Shake reduction CarlCanary Pentax News and Rumors 0 02-13-2008 12:15 AM
All times are GMT -7. The time now is 03:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
