09-28-2009, 07:57 PM   #1
Pentaxor's Avatar
tight K-7 memory card slot, SOLVED !!!
Ok, actually I did this by accident. I was inserting my SDHC card the other day and I was wondering why the card doesn't seem to go in. to my surprise, I was inserting it at the opposite end first (glad I didn't forced it, otherwise the slot could had been wrecked and need a repair or replacement parts). anyway, as I was checking it for any significant damage, the card slot didn't break (no bent mechanism both electrical and electronical and mechanical casing), and it is still able to read (thank goodness). push eject still works and guess what? I could now remove the card with ease everytime. my suspicion is that when I inserted the card backwards, it could had widen the space of the mechanical casing inside. I guess this is a case of a beneficial accident.
09-28-2009, 09:16 PM   #2
GLXLR's Avatar
QuoteOriginally posted by Pentaxor Quote
I think that ruins the weather sealing though... The old K20D/K10D had a tight door that didn't let water in in the first place, where as the K-7 is a sliding door.
09-28-2009, 10:09 PM   #3
Pentaxor's Avatar
QuoteOriginally posted by GLXLR Quote
not really. the weather-sealing (rubber) is attached to the sliding door which covers the whole entrance of the card slot (external) and has no connection to the unexposed internal slot component. to put it in simpler terms, it's like a bottle rubber cap surrounding the glass opening. the exterior part of the card slot is part of the hard casing. I'm talking about the interior which is unexposed.
09-28-2009, 10:41 PM   #4
Mine has just become wider with normal use. If I do the "Push in and shoot the card out" now, it will some times fall on the floor.
I have probably ejected the card 1-2 times each day since I got that camera at launch date.
It will definitely not affect the weather sealing.
accident, camera, card, dslr, k-7 memory card, photography, slot
SD card slot on the K5 jpzk Pentax K-5 36 11-24-2010 08:11 PM
k20d sd card slot problem hitechrr Pentax DSLR Discussion 9 05-02-2010 05:18 PM
Is the SD card slot sealed? (K200D) vk4akp Troubleshooting and Beginner Help 4 05-04-2009 06:22 PM
K200D card cover tight fit Billy Batson Pentax DSLR Discussion 6 01-26-2009 06:15 PM
Realignment of K10D SD card slot without sending it back to Pentax? Narcoleptic Pentax DSLR Discussion 4 09-15-2007 11:34 AM
All times are GMT -7. The time now is 09:48 PM. | See also: NikonForums.com, part of our network of photo forums!
