09-30-2009, 01:00 PM   #16
heliphoto's Avatar
QuoteOriginally posted by RBellavance Quote
If that is the case, then it is contrary to what the manual says. Wouldn't be the first time...
I disagree. Here's the quote from page 122...
In my experience, what this means is that you can set a single adjustment for that lens, press OK, and exit the menu, and you'll be using that adjustment setting, but if you move the cursor back to Apply All and press OK before leaving the menu, you will have set the camera to use the Apply All setting for that lens - it will still store your Apply One setting, but it will use the Apply All setting... you need to leave the menu with Apply One as the active mode for the camera to use that setting.
My previous paragraph is kinda confusing to me , so let me know if that doesn't make sense and I'll try again.
09-30-2009, 01:07 PM   #17
kolouch,
Based on my experience, the -10 might be wrong in judging your 50/1.4. I have exactly this case: when I use the focus chart to test at almost the closest distance, -10 is not even enough, but when I leave it further, -7 works fine, and -7 applies to distant object too.
I made couple of simple tests, like set all to -10 and one to -2 and vice versa. In either case, the results really depend on which section (all or one) I end up with. I don't think you can make a combined effect with apply all and apply one together. As what the manual says, they act individually and override one another.
The debug AF seems like the only right way to go!
Cheers,
Tony
09-30-2009, 01:17 PM   #18
I'll try look into RAW info tomorrow ..
09-30-2009, 02:48 PM   #19
QuoteOriginally posted by heliphoto Quote
I agree (I think ). But either the "Apply All" settting is used, or the "Apply one" is. In no case is the "Apply one" is not added to "Apply All" (which is what I thought you were suggesting earlier).
camera, debug, dslr, k-7, mode, photography
Front focus and back focus K-5 allantois Pentax K-5 & K-5 II 48 03-31-2012 09:21 PM
Trying to understand front focus/back focus thing 41ants Troubleshooting and Beginner Help 16 08-31-2010 08:42 AM
Front/back focus or focus shift? fulcrumx29 Pentax SLR Lens Discussion 0 08-17-2009 04:56 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
How to check Back Focus/Front Focus grishazzz Troubleshooting and Beginner Help 14 03-18-2009 11:35 AM
All times are GMT -7. The time now is 09:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
