Originally posted by RBellavance If that is the case, then it is contrary to what the manual says. Wouldn't be the first time...
I disagree. Here's the quote from
page 122...
In my experience, what this means is that you can set a single adjustment for that lens, press
OK, and exit the menu, and you'll be using that adjustment setting, but if you move the cursor back to
Apply All and press
OK before leaving the menu, you will have set the camera to use the
Apply All setting for that lens - it will still store your
Apply One setting, but it will use the
Apply All setting... you need to leave the menu with
Apply One as the active mode for the camera to use that setting.
My previous paragraph is kinda confusing to me
, so let me know if that doesn't make sense and I'll try again.
