Originally posted by roscot Hi Roscoe,
When you shoot in RAW, the parameters the camera chooses (Contrast, sharpness,saturation) are saved but not applied. If you use the Pentax Software to convert the raw files, the initial settings the converter uses are the camera parameters (other converters ignore them). The advantage of RAW is that you don't have to use those settings, you can easily change them with a great deal more latitude than a jpeg.
Hope this helps a bit.
-Alan
to add to this great explaination, if you use adobe photoshop cs2 with raw, and it is set to have the adjustments (saturation, etc) on automatic, the when the photo opens, Photoshop reads the "saved" settings that Alan explains and applies it to the photo. this way you get a "preview" of what the photo would have looked like if the camera used one of the scene modes, for example kids.
All you would have to do in Photoshop cs2 is uncheck the boxes for automatic settings, and then you get to customize the output of your photo
As far as getting the k100 goes, my wife just got one and it is so simple to use that even she can get off of fully automatic. If you turn the dial to, for instance macro, then on the viewing screen it shows you exactly what that setting is for.
don't let the ease of use fool you, as far as what I have read, Pentax makes products that are easy to use...... just think of pentax being the "Mac" in a PC world.
I have played with it and it takes really good pictures
hope this helps
randy
