10-01-2009, 12:53 PM   #1
Sew-Classic's Avatar
K-7 Dust Removal ??
I've heard and felt the dust removal system on the K20D, and the K2000 (k-m). I recently aquired the K-7, and I don't hear or feel the dust removal. Yes, the camera is set for the dust removal to be activated upon start-up.
Is the K-7 'stelathy' and quiet compared to the other Pentax DSLRs with regard to the dust removal system??
10-01-2009, 12:55 PM   #2
Eruditass's Avatar
I heard it uses a different / better system
The K-7 defaults to run the dust reduction at startup as it is really inaudible next to the sound of the sensor shifting to position (which is just a slight tick noise, sounds like the aperture stepping down almost).
10-01-2009, 01:10 PM   #3
OK- good- so "quiet" dust removal is normal for the K-7. I thought that perhaps is wasn't working since I didn't hear it.
10-03-2009, 08:50 AM   #4
If you listen carefully, you will hear a short buzzing sound, a bit like a charging flash, for less than a second. If you can't hear it during power on, try the manual dust removal from the menu to figure out the sound. It's quite obvious once you know what it sounds like.
10-03-2009, 01:47 PM   #5
Yep, the K7 uses an ultrasonic dust removal system, unlike the sensor-shake dust removal of earlier Pentax DSLRs.
12-08-2009, 06:00 AM   #6
Hello there.
i just got my K-7 and i was wondering what kind of sound the K-7 makes when it shakes it sensor to clean dust.. when i power on my K-7 it kinda makes a screeching sound.. is that okee?. it's really faint but i can hear it.. it's like 2 screeches...
with my Pentax k10d you really FELT it.. but now u don't feel it and the screeching makes me nervous..
so is it okee?.
TNX!
12-08-2009, 06:47 AM   #7
RBellavance's Avatar
QuoteOriginally posted by Vaizard Quote
Hello there.
so is it okee?.
TNX!
Yes, the extremely high-pitched screeching sound is the ultrasonic dust-removal function in action.
12-08-2009, 07:14 AM   #8
QuoteOriginally posted by Eruditass Quote
Indeed, it works at a very high frequency and to my field experience, it is *much* better than my K10D (the K20D uses the same system).
Also, check out the dust alert function.
- Bert
12-08-2009, 11:16 AM   #9
QuoteOriginally posted by Sew-Classic Quote
As others have said - yes is the answer. I can also vouch for the fact that the new system is vastly more effective than previous bodies. Loads of lens changes over several months and I've yet to encounter any dust issues! The system is supposed to be much more similar to Olympus SSWF: acknowledged to be best in class.
camera, dslr, dust, k-7, photography, removal
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
K 7 Dust Removal Question tpeace Pentax DSLR Discussion 3 03-19-2010 02:46 PM
I love Dust Removal! WheresWaldo Pentax DSLR Discussion 7 04-15-2009 07:53 PM
Dust Removal at Start-up: On or Off? rortiz Pentax DSLR Discussion 41 08-26-2008 09:40 AM
Dust Removal working for you? m8o Pentax DSLR Discussion 30 08-26-2007 06:52 AM
All times are GMT -7. The time now is 03:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
