10-02-2009, 08:04 PM   #1
K20 SUDDENTLY won't power on
So, I just used my k20 a few days ago - worked great! But, today when I turn it on it won't do anything. A full battery symbol flashes and quickly goes away and the orange light reading the SD card blinks. Then...NOTHING. I've tried 4 different batteries. I know at least one of the batteries was working because I used it to power my backup (a k10). Does anyone know of ANYTHING that could be wrong. I would like this to be fixed ASAP -- I have a wedding on Saturday and numerous sessions this week.
Thanks for any advice!
10-02-2009, 08:11 PM   #2
heliphoto's Avatar
I bet your SD card is not in the slot... look in your card reader. If the card's in the camera, try removing it and reinstalling it.
10-02-2009, 08:18 PM   #3
The card is in the slot. The orange light blinks and quickly turns off - just as it would when it powers on as normal. I tried removing the card and replacing it. I still get the same result.
10-02-2009, 08:27 PM   #4
What happens when you power up without a card in the camera? Same thing?
10-02-2009, 08:34 PM   #5
yep, same thing. Except that the orange light doesn't come on.
10-02-2009, 09:01 PM   #6
heliphoto's Avatar
Hmmm - forgive me for belaboring the card thing for a second more... Have you tried an alternate SD card, and have you confirmed that your card is not in backwards? (I don't know if it's possible to put a card in backward, and I'm not gonna test it ) I keep going on about this because the symptoms your camera is presenting seem a lot like it's lacking a card.
10-03-2009, 01:00 AM   #7
How old is your k20?
I think there are some electronic problems with some of the Pentax DSLR. I had one myself and others have also reported them. Try removing the battery for a few seconds then put it back and try.
10-03-2009, 04:39 AM   #8
The SD card is not the problem. The camera will power on (normally) with or without a memory card. But, I have tried alternate cards.
I've also tried removing and replacing the battery. I also have tried with a fully charged battery (right off the charger) and I still have the same result.
I bought the camera this past July. So...not very old.
10-03-2009, 04:49 AM   #9
I sympathise with you and your wedding situation.
The electricals have been known to give in in Pentax DSLRs but unfortunatley Pentax will not be able to assist you before your wedding although it is a recouring problem with several customers in differnet models and it seems the only solution is motherboard replacements and that takes several weeks as I got to find out. The two links below have k-7 in the titles but as you can read in the threads, K20 and K10s are also getting the issues.
https://www.pentaxforums.com/forums/pentax-dslr-discussion/74410-k-7-flickering-screen.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/74242-serious-shor...ectronics.html
I hope for you it is less serious and you can get it to work on time for the wedding.
10-03-2009, 04:50 AM   #10
daacon's Avatar
QuoteOriginally posted by Alex2007 Quote
I had a K10D that had a similar problem (don't remember if the SD card light went on though). I tired eveyhting you tried, including brining it into a camera store to try one of their batteries and cards.
Mine had to be sent back and according to the invoice a board was replaced , so there was nothing I could do sorry to say.
By chance do you have the battery grip ? Have you tried with and without the grip ? In the menu it is using the body battery first ?
I think you have donne your due dillegence and it may be time for warrently work, unfortunatley.
10-03-2009, 05:53 AM   #11
I do have the grip and have tried with and without it. I figured it was something internally wrong with the camera. But, thought that I would attempt to find a solution on here. I have an email sent to pentax already (call center was closed). So, hopefully I will hear something by Monday. I plan to ask for it to replaced, rather than repaired. But, that is probably a long shot.
10-03-2009, 06:23 AM   #12
Please let us know how you do with Pentax customer service
I did not get any flexibility from them on my case. I also got mine in July.
10-03-2009, 07:10 PM   #13
I will post new info as soon I have something! Thanks again for all your help!
batteries, camera, dslr, k20, photography, power
Misc That K-x That I Won jct us101 Post Your Photos! 5 06-20-2010 09:48 PM
Power cord for a TR Power Pack 2 Vern Pentax Camera and Field Accessories 4 12-06-2009 08:13 AM
Lookie what I just won! booklady Pentax SLR Lens Discussion 12 10-10-2009 10:38 PM
Cmos Power--k20 Jewelltrail Pentax DSLR Discussion 5 06-30-2008 09:16 PM
I won! rfortson Post Your Photos! 20 02-23-2007 06:18 PM
All times are GMT -7. The time now is 09:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
