10-05-2009, 06:47 AM   #1
K-X specs
hi! i am new in the forum, i have searched for a thread discussing the pentax k-x specs and i have not found any, so i decided to create one
i think i will buy this camera on christmas, but i have some technical doubts about the specs (i am new at dslr)
- batteries, what is the differnece between the lithium batteries and rechargeable NiMH or hybrid? i read with lithium batteries you can reach 1900 shots or 1100 (50% flash) but i will use rechargeable ones, will i notice much difference?
- i also read it will record hd video720@24, do you know if it will include lower res at more fps? is 24 ok or 30 is much better?
- it can make a sequence of 17 jpg at 4,7fps or 5 raw. is that as few as it seems or is it ok?
10-05-2009, 09:43 AM   #2
A couple of responses to your points.
I think as far as batteries are concerned, there are probably several review sites out there that deal specifically with them. I will be using eneloops personally (already have a bunch) and expect to get alot of photos out of a single charge. 700-800 shots is well beyond a day's worth of shooting for me.
24FPS for video, as far as I understand it, is a fairly accepted framerate in the video world (not the only one, but nothing out of the ordinary). I think it is actually generally preferable to 30fps. (note I just typed in 24fps and the first google auto complete is '24fps vs 30fps' which tells me this is a long running discussion!) I wouldn't be surprised to see a lower resolution option, but that is just personal speculation.
The idea behind a short burst of multiple frames is that you have a general idea of what you want to capture (specifically in some form of action shot - sports, wildlife i.e. a bird in flight) - you start your capture slightly before an anticipated moment and capture it within the range. So, you are getting close to 4 seconds of close to 4.7fps, with the idea being that you would capture a specific, ideal shot in that timeframe. Personally I have hardly ever used burst shooting, but since Pentax (prior to the K7 and now Kx) have traditionally been around 3fps or lower, this is a welcome addition for alot of users.
10-05-2009, 11:42 PM   #3
ok, thanks for the answer! i think i will definitely get this camera.
one more questions about the batteries, you get 700-800 photos with eneloops, have you tried lithium? how many more can you get?
thanks again
10-06-2009, 05:35 AM   #4
of course your going to get more shots out of lithium batteries but they wont be rechargeable.
and i dont think i've seen them li ion in AA form?
10-06-2009, 06:42 AM   #5
QuoteOriginally posted by o_bender Quote
thanks again
Those numbers are out of thin air to begin with, haha! But I think they are a reasonable expectation. I have a K20d currently, which uses a proprietary battery - I have no idea how many shots I get per charge - I am not much for machine-gunning and hoping I get something, but rather am more conservative with my photo count in general. With the K20d and grip, I have more than enough charge for a week long vacation (generally speaking). I think the Kx is extremely solid on specs alone. I have no urge to sell my K20d, but think the Kx is a perfect compliment to it.
10-06-2009, 07:19 AM   #6
i think those numbers are enough for me, i have seen some photo examples of this camera and they seem pretty good to me, i will definitely get this in christmas, when i go to new york (from europe) i have heard about b&h, any other recomended store?
WerTicus, i know i'll get more shots from lithium but, do you know the ratio more or less? the double? x1.5?
thanks!
10-06-2009, 07:44 AM   #7
Marc Sabatella's Avatar
Probably about double if it's like other Pentax cameras - 500-ish shots with good low-self-discharge rechargeables like Eneloops, 1000-ish with non-rechargeable lithium (as another poster mentioed, lithium-ion is not an option).
10-06-2009, 07:48 AM   #8
i think that is another advantage, when they release a much better AA type (like lithium-ion or something) it will be easy to update the batteries
thanks!
10-07-2009, 08:10 PM   #9
I use 2000 MAh Eneloops and I'm averaging 751 shots per charge so far. I alternate between 2 sets.
10-07-2009, 08:15 PM   #10
thanks!
Never been to any of the NY stores, but have heard that adorama is also a gadget/camera geek paradise. Would love to see them in person myself someday (I will try and leave my wallet at home, haha).
10-07-2009, 11:29 PM   #11
i have had a k-m (k-2000) in my hands, which are said very similar to the new k-x... does anyone have this camera? am i the only one who hits his nose everytime i try use the wheel? that was a bit uncomfortable... i will try to look for more info about this
i know adorama too, but the web page doesnt seem so good, i dont know where to buy it actually
edit. my fault, im prone to use my left eye and that makes it pretty uncomfortable
10-08-2009, 09:04 AM   #12
here's my take on the batteries. the K-x is rated at 1900 shots for lithiums. although i would think thats a bit overly optimistic, but even 1500 would be good.
i'm using NiZn's and so far, i'm getting over 800 shots in my k2000. The k-x should be even more energy efficient. eneloops are good too. used them in my *ist DL and got about 500 shots.
NiZn's have higher voltage than eneloops. nothing scientific, but i feel the AF is livelier than with eneloops. They're a tad pricier than eneloops and for electronics that needs that extra 0.3v per battery, the NiZn's are great.
YMMV
HTH
jordan
10-08-2009, 09:12 AM   #13
Eruditass's Avatar
I get over 1300 shots on my K2000 with my duraloops (supposedly eneloop rebrands) and other hybrid batteries - but I do run my LCD screen to the lowest setting, short meter time setting, no flash, etc. Never tried lithium.
K-x with its CMOS sensor is supposed to be better.
10-08-2009, 11:22 AM   #14
I checked my K2000 with a set of Energizer lithiums. Came to somewhere between 1,300 and 1,400 shots with very little use of flash. Couldn't be happier.
I use Eneloops for my flash, though, unless I'm traveling and don't want to lug a charger around.
I've not checked the battery life in the K-7. Seems OK but the camera is a bit slow in telling me that the charge is getting low. The three bars are visible for a long time but then it goes to two bars, then to one bar, and finally to "off" entirely too quickly.
10-08-2009, 04:28 PM   #15
GerryL's Avatar
..not weather-sealed though.
What attracted me to Pentax first was the weather sealing..although I ended up with the K100D super for the meantime..till I save up for the K7.
batteries, camera, dslr, k-x, lithium, photography, specs
More K-r Specs Adam Pentax News and Rumors 138 09-13-2010 12:54 PM
k-7 specs?? houstonmacgregor Pentax News and Rumors 11 05-19-2009 05:26 PM
K-7: the specs are known already ogl Pentax News and Rumors 347 05-15-2009 01:16 PM
Specs on MZ-S mr.voigtlander Pentax Film SLR Discussion 2 02-08-2008 02:46 PM
GX-20 Specs ricardobeat Pentax News and Rumors 5 01-24-2008 10:01 AM
All times are GMT -7. The time now is 01:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
