10-08-2009, 11:14 AM   #1
Sharpness VS Fine-Sharpness in k20d
What the difference between the two? The manual doesn't shed much light into it. I can't differentiate them visibly either.
10-09-2009, 11:17 AM   #2
Marc Sabatella's Avatar
Since there's been no answer:
You might try searching for the term "fine sharpness' in these forums and/or on dpreview. There has been some discussion with some good answers (I don't use either, since I shoot RAW). I was also thinking this post probably belongs in DSLR discussion, and am moving it to see if it gets more response there.
10-09-2009, 11:20 AM   #3
Eruditass's Avatar
DPReview has a good explanation:
Pentax K20D Review: 15. Features: Digital Photography Review
In short, fine sharpness will look sharper but you'll see the halos easier.
10-09-2009, 11:21 AM   #4
RBellavance's Avatar
Fine sharpness also seems to accentuate high-ISO noise more than "regular" sharpness, at least in my experience with the K-7.
10-09-2009, 09:08 PM   #5
Itai's Avatar
QuoteOriginally posted by RBellavance Quote
@RBellavance: Correct, that is because fine sharpness uses a fewer pixels to determine edges and noise are generally independent from pixel to pixel.
- Itai
10-10-2009, 05:32 PM   #6
falconeye's Avatar
QuoteOriginally posted by Eruditass Quote
Thanks for the link.
Looks like:
  1. Sharpness is an asymmetric unsharp mask with medium radius and strength as controlled by -4 to +4.
  2. Fine Sharpness is a standard unsharp mask with small radius and strength as controlled by -4 to +4.
An unsharp mask is adding a fraction of the difference between an image and a blurred one using Gaussian blur with given radius.
The asymmetric mask is only adding a fraction of the difference if it is negative.
Technically, both operations are Laplacian image operators and could be applied in combination. However, it looks like one option excludes the other.
10-10-2009, 08:19 PM   #7
Raybo's Avatar
Looks like:
I have no idea what you just posted Falk! ? ?
10-11-2009, 10:58 AM   #8
falconeye's Avatar
QuoteOriginally posted by Raybo Quote
I tried to explain how sharpening works because how else could one understand the difference between two different methods?
Therefore, Unsharp masking - Wikipedia, the free encyclopedia
may be a prerequisite to understand my post
10-12-2009, 11:41 AM   #9
Thanks. This is very complicated indeed. Is PPL/SilkyPix the only tool that provides this "assymetric" USM? I use RawTherapee sometime, and its options are USM (standard, I assume), and RL-Deconvolution (don't know anything about this one either).
Fine-sharpness does seem to accentuate noise more. Probably best avoided.
camera, dslr, photography
k-7 sharpness / fine sharpness / fine sharpness 2 mattdm Pentax DSLR Discussion 10 12-12-2010 08:10 AM
Go fine sharpness! fulcrumx29 Pentax DSLR Discussion 19 08-17-2009 09:45 AM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
k20D "fine sharpness" SUCKS! Too much noise! rburgoss Pentax DSLR Discussion 8 06-22-2008 06:59 AM
All times are GMT -7. The time now is 04:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
