10-13-2009, 02:07 PM   #1
Fl_Gulfer's Avatar
K20d Problem
I took both photo's with the same settings with my K20d and K100d and Sigma 100-300 on a tripod the exact same distance. So what is wrong with my K20d? The K100 takes a much clearer photo.
Click to enlarge to see the 1600x1200 shots.
K20d
K100d
Thanks Guys & Gals
10-13-2009, 03:14 PM   #2
imtheguy's Avatar
You seem to be an experienced photog so I don't know why you post two shots with no information about the camera settings and want us to guess at what is different. At least we can see the ISO, f-number and exposure time are a little different between the two. The color difference may be due to the K100 using sRGB for its color space while the K20D has an "unregistered" color space that obviously is not a camera setting, maybe changed in PP. A hundred other menu settings affect the picture. What exactly are we looking for?
10-13-2009, 03:27 PM   #3
causey's Avatar
The K20D pic seems underexposed.
10-13-2009, 03:30 PM   #4
Ash
Community Manager
Ash's Avatar
By same settings do you mean same Tv, Av and ISO in M mode for both cameras?
Or do you mean same camera mode but auto metering?
More info required for sure.
10-13-2009, 03:49 PM   #5
jeffkrol's Avatar
QuoteOriginally posted by Fl_Gulfer Quote
K20d
K100d
Thanks Guys & Gals
Besides the WB and exposure differences??... Anyways it seems the k20 front focused a bit. Aperature looks fairly large (by my guessitmate) and DOF is not very deep...
10-13-2009, 04:00 PM   #6
Fl_Gulfer's Avatar
Sorry they were both set on the green setting, ISO is on Auto. I set everything so the camera would make the best settings on both. I was mainlt wondering about the poor focus of the K20d, I always wondered why the K100d took much better shots.
10-13-2009, 05:09 PM   #7
Marc Sabatella's Avatar
"Best" settings in theory for some purpose, maybe, but th camera can't read you mind as to your intent, and the settings chosen by the K20D were not ideal for your particular particular purpose here. According to the EXIF, the K20D chose ISO 100 and f/4, yielding a shutter speed of 1/350", which would have been great *if* you had managed to hold steadier than you did, and if you didn't mind the shallow DOF that resulted from shooting 300mm at f/4. The K100D doesn't have the option of ISO 100, so it went to ISO 200, whicvh gave you a faster shutter speed, which enabled you to get a less blurry photo. Also for whatever reason chose f/4.5, which yielded slightly more DOF - probably just enough to create the illusion of a sharper photo. Then, on top of that, the K20D happened to choose to focus on a part of the dummy that was a little forward of the part of the dummy the K100D chose to focus on.
Uless your particular K20D is defective - and nothing about this test suggests it is - then it should be capable of doing as well as or better than the K100D. You can't base too much on one test like this where you failed to control any of the basic parameters that contribute to the things you are testing for.
10-13-2009, 05:40 PM   #8
creampuff's Avatar
Exposure and ISO not to mention auto settings between the two images are different. So naturally the images will look different.
K100D: 1/500sec at f/4.5 ISO 200 Portrait mode
K20D 1/350 sec at f/4 ISO 100 Program (Auto)
10-13-2009, 05:51 PM   #9
there is exif info on those images.
go to online exif viewer like:
Jeffrey's Exif viewer
and put in the url of the image.
K20D Image
10-13-2009, 07:11 PM   #10
Ash
Community Manager
Ash's Avatar
Then the results are just not comparable.
Green mode takes over far too many variables - or perhaps the comparison is between two green modes from two different cameras...
Either way, there's no 'problem' with the K20D from what we see here.
10-13-2009, 07:17 PM   #11
Fl_Gulfer's Avatar
These photo's were taken on a tripod with a wired remote switch. I unscrewed the camera from the lens while on the tripod as to not move anything.
I know the lighting is different but the focus should have been the same on both shots. The k20 is no where close to as good as the K100.
All this time I thought it was my wife having a steadier hand, but now that I spent all this money on a great tripod I see its the camera thats screwed up.
10-13-2009, 07:21 PM   #12
I still don't see evidence of that. Like I said, the cameras appear to have happened to have chosen two different areas of the image to focus on, and the K20D was saddled with a wider aperture - meaning less DOF, and also a simply less sharp image. As for the tripod, I take it then you used the two-second timer?
There's still just far too many vairbales to conclude anything meaningful from this test. Shoot a series of images while controlling the focus better and using the *same* exposure before leaping to conclusions.
10-13-2009, 07:22 PM   #13
rfortson's Avatar
I agree it's hard to draw conclusions from these two shots. However, I'd consider taking some more shots with the lens/K20D combination to see if others are slightly OOF. If so, you should try the in-camera adjustment. I was always a little dissappointed in my Bigma shots, but I adjusted the focus in my K20D and now the shots are just a little sharper, and that makes all the difference.
BTW, on the K20D shot, did you wait for the SR to engage before snapping the shutter? It looks like you could have a slight bit of camera shake.
10-13-2009, 07:28 PM   #14
Fl_Gulfer's Avatar
I'll take some more shots tomorrow after class to show you what I mean. I'll make sure everything is the same.
10-13-2009, 09:56 PM   #15
imtheguy's Avatar
QuoteOriginally posted by rfortson Quote
It better not have engaged on a tripod mounted, remote fired shot.
camera, dslr, k100d, k20d, photography
k20d problem Neto Pentax DSLR Discussion 2 09-24-2009 02:59 AM
K20D Problem photoTaz Pentax DSLR Discussion 2 06-21-2009 09:25 PM
Just got my K20D... problem already - need help! dimak Troubleshooting and Beginner Help 6 05-01-2009 04:21 AM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
Problem with K20D eadnams Pentax DSLR Discussion 7 06-28-2008 07:21 AM
All times are GMT -7. The time now is 10:17 PM. | See also: NikonForums.com, part of our network of photo forums!
