Hi All,
Just returned from a 2 1/2 week vacation travelling around Argentina. Unfortunatly those pantagonian winds blew the K20D off the tripod, unfortunatly a rock made a direct hit with the rear e-dial, knocking it into the body.
Overview of the damage.
- Rear edial misplaced, can still be turned with effort but is basically unusable.
- Upper LCD screen cover popped out and cracked in half. Screen itself seems ok.
- Was surprised with this part... seems like the impact on the rear pushed the insides forward to such an extent that it broke the front of the body... there is a crack on the body below the flash... flash still closes if pushed down firmly.
- Camera does not turn on... on trying a flashing battery is seen on the upper screen... I did try and recharge the battery and try again but same flashing battery signal.
Made contact with the group handling the Pentax repairs for the UK. they suggested (with the info given above) that the main PCB was likely broken. and that the starting charge for fixing a Pentax DSLR is approx 160 GBP.
any experience in this type of damage and how much its likely to cost. Goes without saying that depending on the repair charge it may be better to pick up a new K20D body... or maybe a K7
On a positive note... this was the only dark cloud in the vacation... vacations were great... were very lucky with weather etc... and did manage some great shots (i think) before the K20D met its end... did have a backup camera (P&S Olympus), while not great at least we still captured the memories.
Thanks,
Paul
