10-15-2009, 01:54 PM   #1
K100D Super Shake Reduction problem
It is simple,really..
When i use an A-series lens(i.e. smc-a 50mm 1.7),i can use the SR feature without any problems,but with F-series lenses,or my Tamron 28-75 2.8(i only got these anyway)SR is grayed out.Does it mean it can read the focal lenght,so it doesnt need me to select it?Or are there any problems?
10-15-2009, 02:18 PM   #2
Marc Sabatella's Avatar
If the SR menu is greyed out, it means the camera was able to figure out the focallength itslef (true of most if not all AF lenses). If the little hand lights up the viewfinder when you half press the shutter, you should be good to go.
10-15-2009, 08:38 PM   #3
res3567's Avatar
Greyed out means your lens is communicating with the camera fully and the camera automatically knows what to set SR for that particular lens. When you have to set SR manually, little to no communication with said lens. More or less the same technology that tells the body what the focal length and apeture of AE lenses. Usually, like Marc said, most AF lenses fall into this category.
camera, dslr, photography
Shake Reduction/Over Exposed Images Problem Jeff Lowe Pentax DSLR Discussion 20 06-19-2010 09:05 AM
K100D Super - SR (shake reduction) on tripod JGabr Pentax DSLR Discussion 1 01-17-2010 05:18 PM
Pentax K-7 Shake reduction problem raywheeler Pentax DSLR Discussion 34 12-01-2009 09:30 AM
K20D shake reduction problem? DanielT74 Pentax DSLR Discussion 4 10-02-2009 10:32 AM
Shake reduction on K100D DavidH Pentax DSLR Discussion 8 11-20-2007 01:53 PM
All times are GMT -7. The time now is 05:25 PM. | See also: NikonForums.com, part of our network of photo forums!
