10-17-2009, 11:42 PM   #1
Jatcat's Avatar
K20D: Loose/wobbly four-way controller button...
Just bought a new K20D and right out of the box noticed the four-way controller and "OK" button are a bit loose/wobbly.
Anyone have a similar issue or know if this is "normal"??
Thx.
10-18-2009, 01:57 AM   #2
wwwmorrell's Avatar
QuoteOriginally posted by Jatcat Quote
Thx.
My K20D OK button is loose/wobbly if wriggled but the four-way controller is quite firm, at least on my camera. ?????
10-18-2009, 03:26 AM   #3
tomtor's Avatar
It's normal that you can move it around a bit. It is not firmly fixed to the body, there is rubber plate under it to make it sealed against water and dust.
10-18-2009, 03:30 AM   #4
Thx.
That's a hard one to quantify online...what is perceived as "loose" to one person is stiff to another and just right to yet another person. If you feel it's not right, retrun it for an exhange or find someone who has one and see how their's feels...or send it in for a check under your warranty.
good luck with that one...hope it's not a big deal...
10-18-2009, 03:49 AM   #5
I purchased two K20D in August and both have a loose feeling ,when moved side to side. I also notice that the most of the other control buttons have a little side movement. I was alarmed as well, so called Pentax Imaging. They stated that sideways movement of the external control buttons is normal. And in no way affects use or waterproofing.
10-18-2009, 04:02 AM   #6
Ash
Community Manager
Ash's Avatar
Indeed hard to know just from a description, but there is some play with both the OK and 4-way controller - even other non-flushed buttons can be considered having similar play with them.
camera, controller, dslr, k20d, photography
K10 button.....loose? JCorwin Pentax DSLR Discussion 10 05-08-2009 11:29 AM
Loose buttons on K20d Schwatmann Pentax DSLR Discussion 4 02-27-2009 12:46 AM
Position of K20D AF button Arpe Pentax DSLR Discussion 13 11-03-2008 04:22 PM
K20D + grip AE-L as AF button? morfic Pentax DSLR Discussion 7 10-08-2008 05:19 AM
Wobbly M42 adapter on K20D pingflood Pentax SLR Lens Discussion 4 08-10-2008 04:50 AM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
