10-22-2009, 12:11 PM   #31
And see if Pentax has allowed us to turn OFF dark frame subtraction in exposures longer than 30 seconds.
Anybody know if this can this be done (turn off DFS over 30 sec. that is) with the K-x ?
10-22-2009, 12:27 PM   #32
The good and the bug
Well this might be a big experiment i mass psychylogy. But I'm pretty confident I see the following:
1) IQ at high ISO JPEG:s is better both concerning noise and edge sharpness (the new Fine sharpness 2-setting). It seems 1600 is quite smooth and 3200 still useful for some purposes.
2) Focusing in low light is better, at least with SDM lenses, at least with the DA 17-70/f4. Ive had reason to despair about the AF-performance of this lens, but now it works instantly, albeit not more accurately than before. I have tested it in the exact same lighting conditions as earlier, it's a windowless space.
I'm sure something has been done to the focusing because a new bug has been introduced into it: In Live View and Contrast focusing (or Face recognition) you cannot move the AF point around anymore. This is clearly a bug.
But any improvement on focusing speed is appreciated nevertheless, thanks, Pentax !
10-22-2009, 01:32 PM   #33
Ok, I may be imagining things, but the above post got me to try some low light AF and it seems like the AF-assist lamp is more decisive - before te camera could not make up its mind whether to turn on the lamp or not - now it seems to engage almost instantly if needed. It seems in low light he K-7 pulses the light on and deterines whether it's actually doing anything. It also turns the light on to check focus, then off as the lens motor moves into the expected focus position and then on again to verify as needed. Was this the behaviour before?
Kameraten - I cannot replicate the bug you mention, could you provide more details? Movig the AF point in contrast-AF works just fine for me...
10-22-2009, 01:36 PM   #34
netuser's Avatar
QuoteOriginally posted by Kameraten Quote
1) IQ at high ISO JPEG:s is better both concerning noise and edge sharpness (the new Fine sharpness 2-setting). It seems 1600 is quite smooth and 3200 still useful for some purposes.................... !
Anyone else come to the same conclusion ? about jpeg engine/high iso use ?
10-22-2009, 01:40 PM   #35
falconeye's Avatar
I think you have fallen into the following trap:
In LV, AF point can only be moved if:
1. Focus point selector is set SEL
2. Focusing is AF (not manual)
3. You press OK
The last step (press OK) may have been configured to be not necessary. However, this configuration was lost by the firmware upgrade which makes the setup fall back to defaults. You probably missed #3.
10-22-2009, 03:27 PM   #36
Well, after a quick try, I found out that videos using pre-A manual lenses no longer overexpose crudely at the start...
There is still a slight lightness decrease for the first 1 or 2 seconds, but nothing bad...
Before, the first frames were totally white...
In fact, we can still see that white-out on the LCD when starting a record, but those first overexposed frames seem no longer recorded...
10-22-2009, 03:49 PM   #37
jgredline's Avatar
I am getting excited here boys. I am just waiting for a customer to pick up his stuff and I am out shooting
10-22-2009, 06:21 PM   #38
JPEG Test with new firmware. Direct from camera.
ISO TEST:
1. ISO Speed: 100
Large: http://farm3.static.flickr.com/2520/4035483023_bace7c458d_o.jpg
2. ISO Speed: 3200
Large: http://farm3.static.flickr.com/2670/4036243230_65f6c957a2_o.jpg
SHARPENING TEST:
All 3 were shot at ISO-100, F/5, and 1/200th shutter speed.
1. Default Sharpening.
Large: http://farm4.static.flickr.com/3484/4035500155_bc1d878d35_o.jpg
2. Sharpen Fine.
Large: http://farm3.static.flickr.com/2733/4036255518_ced99239d5_o.jpg
3. Sharpen Fine 2.
Large: http://farm3.static.flickr.com/2558/4036260216_c0b1ed6d4d_o.jpg
10-22-2009, 07:27 PM   #39
Trig's Avatar
Just in case this happens to anyone else, I just tried to update my K-7's firmware to 1.02. Followed the instructions very carefully. When I went to select YES on the update, the screen very briefly showed that it was updating and then went blank. I could not turn the camera back on at all, everything I tried did not work until I removed the battery and put it back in. Only then I could turn the camera back on. I nearly had a panic attack during this
Anyway, after all that I was able to update to the 1.02 without problems. So, if this happens to you try what I did.
10-22-2009, 07:47 PM   #40
jgredline's Avatar
I just spent the last 4 hours wasting time with this and getting me really mad which is hard to do.
First off, the cam had problems focusing. Unless there was allot of contrast, it would not go...Before this was not an issue...The noise is the same ugly noise and fine 2 is a joke..Introduces so many artifacts...Thirdly, I had to remove the lock and focus that fires when it is focused or it simply would not go...The exposer was also not good. Blown highlights even when facing away from the sun...I purposly shot at ISO 800-1000 and it is a joke...All I want from my K-7 is to control noise like my 2 K20D's... That would make me happy....I say Ok...Perhaps I did something wrong...I re-installed V1.2 and it was the still the same...I said, maybe it was the download, so I downloaded it at work and it was the same thing.........So I did end up fixing it though...I went back to Version 1.01...It now focuses great, fast., positive...Problem is that it is as noisy as Peggy Bundy...
10-22-2009, 08:17 PM   #41
Do you have a link to 1.01 for those that want to revert back? All I see on the Pentaximaging site is 1.02.
10-22-2009, 08:33 PM   #42
heliphoto's Avatar
Bad news Javier! Thanks for the report. I think I'll wait a bit (since I don't think I saved the old update version)...
10-22-2009, 09:00 PM   #43
jgredline's Avatar
QuoteOriginally posted by r0ckstarr Quote
I just saw your images you posted and they pretty much affirm what I saw. Not good. I uploaded the Green Line syndrome fix firmware version 1.01 to my still under construction website.
You can download it here...
10-22-2009, 09:03 PM   #44
Zebooka's Avatar
http://www.pentax-hack.info/firmware/k7/k7_e101m.zip
10-22-2009, 09:30 PM   #45
jgredline's Avatar
Just in case anyone wants to see the catastrophy that went on with my K-7 and the ''new'' firmware fix, here are 100% crops all at a measly ISO800...You really don't want to see the ISO1000 images...Those who know me, know I am not a pixel peeper, but these are so bad, that I could see the noise on the Cameras LCD....This problem is now fixed with the old firmware....My K20D's at ISO 800 are super clean. Infact, I usually shoot those at between ISO640 and 1600 AND DON'T THINK about it to much...
All exif intact, I think.
camera, dslr, firmware, k-7, photography
Firmware? Naturenut Pentax DSLR Discussion 10 08-03-2010 06:37 AM
K-7 Firmware 1.02 konraDarnok Pentax News and Rumors 1 10-22-2009 08:01 AM
New K7 firmware... dlacouture Pentax DSLR Discussion 9 10-07-2009 10:09 AM
When do we get the new firmware? ottoangel Pentax DSLR Discussion 1 04-19-2009 12:05 PM
Firmware 1.11 benjikan Pentax DSLR Discussion 21 03-15-2007 10:41 AM
All times are GMT -7. The time now is 11:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
